cybercarl wrote:Inertia and rotating mass!
Markus what's you view on the less mass making the bike harder to start and easier to stall at idle. Everything has it's pro's and cons so it would be good to know what are the cons specifically with the big twins. These are big pistons to move around which requires energy and the rotating mass helps with that.
Well... That depends entirely on the engine...
On my "street" engine it makes no noticeable difference to starting, it tends to start on the second turn over, or third every time... I'm using a LiFePO4 battery, so first rotation is weak, second is good, and it starts easy... No problems with stalling either... But that engine has a comparatively mild tune... (135-140 Rwhp depending on the weather)
On the race engine, which has an entire different tune, it makes a difference... But that's more a result of the fact that that engine has quite a bit more aggressive cams, and different compression... It's not very easy to start, period... Doesn't much matter what flywheel you use really, it has a nasty morning temper regardless (or well, plain and simple a nasty temper really, come to think of it...) And it's very prone to stalling on idle, or having odd hiccups or carbfarts at just off idle... But that's a compromise I'm willing to live with... 150+ Rwhp has it's drawbacks...
Generally, yes, if your bike is a bit cranky (pun intended) it makes matters worse... But then I'd start finding the reason for that instead of compromising on the lightened flywheel... On a bone stock, or just carbtuned engine, it makes no difference what-so-ever unless the bike has other issues...
