Manual Gear-change indicator
Test your messages here, beginners welcome..
simo
Post by simo »
Managed to get this fitted, made easier with having Pyramid lower fairing mountings/brackets to mount contacts
Image[/url
[URL=http://s1241.photobucket.com/user/jackjoe12/media/Mobile%20Uploads/2014-03/460A8226-C816-41AB-8C10-C85EFED304FD.jpg.html]Image
Theres A Hare in The Turnips.
Re: Manual Gear-change indicator
Dose it work ?
Jscobey
Post by Jscobey »
wow thats awesome. where did you get that?
i dont understand what is mounted down by your gear shifter. can you explain?
macdee
Post by macdee »
nice bit a work there simo
simo
Post by simo »
Yes it works. Cost £14.50 off EBay Two sensors with the wires on mounted on an alloy angle bracket. A fused live to power after the ignition is turned on. One wire to neutral light switch. The alloy bracket on gear change lever holds a small but strong pulse magnet. That's the hard bit as the magnet has. O mounting points. Mines crimped and glued in place. After that it's a case of getting the correct clearance between magnet and sensor. Don't see a lot of it once the lower fairing is back on. Most of the credit must go to Bluestorm996 who did most of the brackets at the same time as he did his. I think they're great for the money, see how long they last.
bsabloke
Post by bsabloke »
http://www.exhausist.com/motorcycletensioners.php
vtrdh on the forum has stock & is selling plug & play kit. the link above gets to his website :D
simo
Post by simo »
bsabloke wrote:http://www.exhausist.com/motorcycletensioners.php
Others on sale plug into the ECU. That ok for newer bikes but for a Firestorm you'd have to hack into the harness and who knows what wires to look for. Someone might tell us.
Mav617
Post by Mav617 »
Not cheap though...
bsabloke
Post by bsabloke »
didn't fancy it myself. I think I an right, it was plug & play. how much was it?
simo
Post by simo »
Don't see any at the moment on EBay , they're from Hong Kong but a British Seller. Expect to pay £15 ish.
budd
Post by budd »
I've now gone all European and bought a KTM Superduke GT and Aprilia RSV1000R :D ,
Storm is now gone :cry: .
simo
Post by simo »
Nice find Budd. Only £10.99 too.
budd
Post by budd »
budd
Post by budd »
or you can build your see the link for instructions
http://www.electronics-lab.com/projects ... index.html
simo wrote:Managed to get this fitted, made easier with having Pyramid lower fairing mountings/brackets to mount contacts
Image[/url
Cheap enough mate :thumbup: , keep us posted on its reliability :D . You might have problems with the bike changing gear too fast having a blue led :lol:
