Advice needed
scouse645
Advice needed
Post by scouse645 »
After checking the connection on the starter motor i found the nut was seized and rusty :x after doing my usual and rounding it off i used a hacksaw to get it off, it wasn't giving trouble, i just checked it before i did get trouble, i also found the rubber that goes over the nut is cracked, what is that bit called? and were can i get it? thanks :)
macdee
Re: Advice needed
Post by macdee »
Try david sliver spares
Part number 32411 253 000
Here we go
https://www.davidsilverspares.co.uk/par ... 411253000/
scouse645
Re: Advice needed
Post by scouse645 »
That's the one, thanks for the info macdee :thumbup:
Re: Advice needed
And it's called COVER TERMINAL *G
So now you know.
scouse645
Re: Advice needed
Post by scouse645 »
got one on order, thanks to tony i even know what it's called :?
