After some tech info please
maxiboy
Post by maxiboy »
Got a project on the go and need some info..
I believe the vtr1000 pistons come in two sizes 98mm and 100mm in the rc51..
are they the same pin height and does anyone know what it is please..
also does anyone have the sizes for the conrods please small end diameter ? big end diameter ? rod length between journal diameters etc bearing width also... thanks in advance ...
maxiboy
Re: After some tech info please
Post by maxiboy »
no one with any info
Maybe because this is an SC36 forum. Do you have an SP or a Firestorm?
You're probably after something like this:
For rod specs, just pick up a scrap rod and measure- then do the same from an SP.
If you need one I can post, unless you're local?
maxiboy
Post by maxiboy »
Thanks very much for the info
not done a lot with the bikes so was unaware i was on the wrong forum thanks for the info..
yeah was after that sort of info.. I will do ebay and pick up some items to measure up ..
converting an alfa romeo V6 to a larger bore and pistons look ideal match..
thanks
Apparently Porsche have a piston with the correct 98mm bore and crown-to-pin height, also pin diameter.
Worth a trawl....
maxiboy
Post by maxiboy »
Amazing info
thanks tony.. not sure whether to go 98mm or 100mm at the moment
doing loads of research at the moment on what I can get to work most efficiently.
thanks will search my piston books and see what i can find
It'll be the liner wall thicknesses that dictate how big you can go with pistons.
I'd suggest anything less than 3mm wall thickness is a concern.
I should emphasise that the info i posted for you is from JE high compression pistons, the standard ones have a flatter head, with indentations rather than crowns.
And to save you trawling ebay I can post you a piston and con rod (they're the same front and rear) for £10 plus the P+P
maxiboy
Post by maxiboy »
that would be amazing mate
how would you like to do this..
my postcode is SA311LN if you need to get shipping costs
