blackbird clutch master cylinder
has anyone used a blackbird master cylinder on there firestorm/superchicken?
having just fitted the cbr600 brake m/c with the rectangular master cylinder, i'd like to match the style with the blackbird clutch m/c, but i'm not sure if the bb m/c will do the same job, or will it be better/worse?
has anyone tried one????????
also I've just ordered some ASV levers, without thinking I ordered them for a firestorm, but now I've fitted the cbr600 m/c, will the new levers fit...... :(
I still have the chance to contact the seller(calsports) and change my order, so again does anyone know if the vtr levers will fit the cbr600 and bb master cylinders????????
Re: blackbird clutch master cylinder
The vfr clutch master is a 14mm same as the storm and uses the same lever but looks the same as the cbr brake master .
lloydie wrote:The vfr clutch master is a 14mm same as the storm and uses the same lever but looks the same as the cbr brake master .
cheers lloydie, is that the 750 or the 800???
Tried one- you get a chirp pulling away in the morning.
Also the same one used on a Wing, apparently.
