Carl, Carl, Carl... what is to be done with you? lol
regarding the fuel screws, it refers to the numbers of turns out from fully bottomed (so yes, they are quite lean)
In my experience, the number of holes affect slide lift speed. I tried many configurations, up to and including 4 holes. With too much "holeage" (lol), the lift lifts too quickly, leaving a puff of unburned fuel when cracking the throttle aggressively (granted, I have an HRC tube so it doesn't take much movement to get you into rapid slide movement territory). It doesn't affect much else (never paid attention to slide bounce as I can't say I ever really felt its effect, except perhaps at idle).
I too was (and remain) quite surprised by the small pilots (truthfully, I could/should be using 38s with the fuel screws set at around 2 turns out), but the engine doesn't lie. The needle and mains are also leaner, though not quite to the same extent. My only explanation is that the lid flows so much more air, that it increases the "pull" through the jets, flowing a lot more fuel through the jet. Only by using a significantly smaller jet (hole) can this extra vacuum be countered. An engine being a fancy air pump, I see this as being very positive, since reduced resistance to airflow (as is the case when the engine has to breathe through the snorkel) prevents the engine from operating at its potential (something Roger noted when I showed him my post-rebuild dyno results; he noted the the engine should be producing more if only it could breathe better). It now breathes... and runs very, very well.....
Finally, I am indeed using the HPower long trumpets.......
