New OCMD project?
mik_str
New OCMD project?
Post by mik_str »
So, am giving some thought to replacing the OEM mechanical water pump with an electric unit (as some on the Superhawk forum have done). This would for the following two reasons: reduce mechanical drag (free up some power, maybe 2-3 hp?) and also to get better management of collnat temps (with use of a digital temp controller). Part 2 of the project would be to replace my existing oil cooler (air-to-oil, same design as OEM, but larger) with a unit from a CBR900RR (Fireblade), which is a liquid-cooled design (Honda CBR900 CBR 900 RR CBR900RR 1996 Engine Oil Filter Cooler Bolt Set | eBay).
This part would serve two purposes:
1) would provide a better management of engine oil temperature (especially if used with a controller on electric water pump), good for engine longevity
2) slight lowering of center of gravity (remove cooler and oil from its present location right up close to the steering head and dropping all the relevant replacement weight to down low adjacent to the oil filter). Minor, I know... but hey, OCMD remember :)
Thoughts?
mik_str
Re: New OCMD project?
Post by mik_str »
after further thought.... this one will stay on a shelf, lol
Ha ha that was quick !!
mik_str
Post by mik_str »
yep.... lol
I looked at the leccy pump and controller, but it seems an expensive way to buy 2Bhp.
When I'm running a high comp/ignition advancer combo I run a four=row oil cooler from an SP1 and it keeps it in the normal standard range.
mik_str
Post by mik_str »
Am running an SP1 oil cooler at the moment too, have been for about 6 years now...... was just looking at something different (am running out of mods..... :cry: ) lol
SO are you getting overheated oil?
mik_str
Post by mik_str »
No.... just my OCMD mind looking for things to do....... lol
mik_str wrote:No.... just my OCMD mind looking for things to do....... lol
Nitrous
mik_str
Post by mik_str »
not a big fan of nitrous...... fun only lasts until the bottle runs empty..... nice try though :)
Stephan
Post by Stephan »
tony.mon wrote:I looked at the leccy pump and controller, but it seems an expensive way to buy 2Bhp.
electric water pump is pretty cheap mod, you don´t need to control operation - see here if you trust :-) http://www.superhawkforum.com/forums/mo ... ers-32464/
All you need is EBP and some hoses and clamps to connect. And you have to be able to connect it - have no doubt you are :-)
Actually you can buy Bosch pump, it is exactly the same as Davies Craig. I bought Davies Craig, and there was BOSCH molded on the body of the pump.
Mik I'm worried that this OCMD is starting to become a problem. There are helpline numbers for these addictions :lol:
mik_str
Post by mik_str »
I know... on the positive side, I managed to turn back the tide in record time in this latest episode, so maybe there's hope, lol
mik_str wrote:I know... on the positive side, I managed to turn back the tide in record time in this latest episode, so maybe there's hope, lol
The tide can only be held back for so long.... it'll be back! :lol: :thumbup:
mik_str
Post by mik_str »
words of wisdom, lol
