i'm absoulutly positive mine is carb related,
i've also stripped them till im blue in the face,tbh i stripped them that much i convinced my self it was electric
(replaced plugs , coils, icu amplifier)
so concentration back to carburettotooters,
stripped them today convincing myself that my first diagnoses was correct (suspect pilot jet issue)
give the sods a real good blow out,had some one with better eyes than me to check them,all good and clear,
back together set the mixures to fully in then 1 1/2 out,then refitted tonight with refreshed vigour,
no better ,will have to source substitute set (ALZ 4321 if your still using this site may be calling you tomorrow mate)
(its that bad i've put the DB killers back in cause annoying the sh1t out of me)
setting my carbs up
Re: setting my carbs up
if you are standard pilots, 1 1/2 is not enough..... check the docs and the pilot sizesBluefox wrote:i'm absoulutly positive mine is carb related,
2.5 front and 2,25 rear for 48 pilots (defualt)
aftere finally getting my bike running good in standard trim ...... i went for it today.
Got my high level Arts on, no baffles
6 sigma jet kit i have had kicking around for ages
190 mains (180 are included as well, but i went large)
50 pilot
Drilled slide
1 coil clipped off slide spring
Needle up with two shims provided
TPS round to about 500 ohms
K&N filter
Mixture screw at default for 48s
Interesting results!!! for a first stab
Fast blipping the throttle from idle make it pop as a result of the slid moving faster than the fuel i guess. However, it rides sweet through to 4000rpm. Definitely feels more grunt, seems easier to lift the wheel on a roll on.
Coming of 4000rpm it is notably more randy, with the wheel lifting over bumps i never noticed before..
It feels like it is dropping off as it goes past 7000rpm but it is still strong .... i may try a 180 main.
After struggling with lean running, i can safely say it is not lean anywhere know.
I am not a big believer of changing every thing at once but pretty much followed the instructions on the kit and got a pleasant surprise.
May be a few more tweaks (leaning out here and there) before Mallory but i think it is good to go
50 pilot
Drilled slide
K&N filter
I've had them both out about 3 turns,with still no joy
It's not your fuel mixture screws then.I've had them both out about 3 turns,with still no joy
What's your symptoms?
Mr Foxcybercarl wrote:It's not your fuel mixture screws then.I've had them both out about 3 turns,with still no joy
May be start a new tread will all settings, add ons, and symptoms. it helped me..... but it was a time consuming process.....
for me when i got to this stage i knew it was blocked pilots because everything else had been eliminatedBluefox wrote:I've had them both out about 3 turns,with still no joy
Sounds like blocked pilots.Bluefox wrote:Hey Stu did you actually pin point the problem mate,mines doin exactly the
same 3-4k,
