Break pads
NT1000
Break pads
Post by NT1000 »
Hi guys. Has anyone used these break pads, are they ok?
http://www.ebay.co.uk/itm/270779039489? ... EBIDX%3AIT
Steve6088
Re: Break pads
Post by Steve6088 »
I've used them on the back. They wear real quick iirc.
I'm always happy to put cheap pads on the back but not on the front
cheekykev
Re: Break pads
Post by cheekykev »
I've used quite a few different brake pads on my Storm and on my SP2, In my opinion the best pads to use are the original Honda (Nissin) ones, they are great for normal road use and more, to be honest I'm sure they're around the same price, maybe a couple of quid dearer, so it would be a no brainer to me anyway
I think if you spend an hour to clean/rub your discs with scotchbrite, clean your callipers and pistons, change the fluid and put the original Honda ones in you'll be quite surprised.
Don't ever skimp on Brakes or Tyres, you will probably need to use them to their full potential one day.
Like what you do
Do what you like
kev64
Re: Break pads
Post by kev64 »
Im gonna fit new pads in the next few weeks, could do with some imput on this subject as well
Might look and see how much the Honda ones are and put some cheap ones on the back
Re: Break pads
Honda or ebc HH on the front and any GG on the rear
Re: Break pads
iv used those before but not on my storm. i found them good but they are soft and do wear very quickly.. iv put a set of armstrong pads in the storm and think they are the bizz so far
mik_str
Re: Break pads
Post by mik_str »
I have always had better luck with brake pads....... break pads just don't seem to last....
NT1000
Re: Break pads
Post by NT1000 »
Thanks guys I will go for the genuine stuff.
NT1000
Re: Break pads
Post by NT1000 »
Thinking of changing the fluid as well. Is this straight forward, is there anything special I will need?
Re: Break pads
NT1000
Re: Break pads
Post by NT1000 »
Is this for blood transfusion? 8O
NT1000
Re: Break pads
Post by NT1000 »
What is it for?
Re: Break pads
Attach to the bleed niple and draw the fluid and air out the lines. Or you could get a colostomy bag http://www.vtr1000.org/phpBB3/viewtopic ... ing+brakes
It's simple enough to change your fluid. Keep pumping the brakes until the old dirty fluid comes out and replace with good stuff.
Re: Break pads
NT1000 wrote:What is it for?
Draw the old fluid out...
More importantly push the new fluid in from the bottom...the air is pushed up, less bleeding required...much less in fact. :thumbup:
NT1000
Re: Break pads
Post by NT1000 »
Thanks guys I think I will invest in one of those bags.
