Before I took the back end apart I managed to start her up after about 3 years idle. She seemed to run smoothly enough but with a very low tickover, well under 1000rpm. The choke cable was slipping a bit, but when I pulled it out and held it the rpm went up. Seemed to be OK opening the throttle too.
As the engine warmed up opening the throttle cause the bike to stall. It started again but would stall unless the throttle was opened very slowly.
Any clue how I should start diagnosing the problem? I'm thinking it's just the idle screw that needs adjusting, but could be the idle jets, or a blockage in the carbs. I probably should have drained the old fuel out first
