airbox foam
thomas111
airbox foam
Post by thomas111 »
Hi guys I no its been covered before were will I get replacement foam
Re: airbox foam
Get some aquarium fish tank filter foam or the more expensive airbox Kart filter foam and cut to shape. It doesn't have to be anything special. Give a light coat of oil when in place. All it does is prevent fine particles getting inside the carb diaphragm which can work it's way out through the slide hole and into the throat.
thomas111
Re: airbox foam
Post by thomas111 »
Thanks Carl will get on flee bay does it have to be a certain thickness as got new car sponges here
Re: airbox foam
No specific thickness. As long as it's close to what you have it's all good otherwise you will need to trim it down.
cheekykev
Re: airbox foam
Post by cheekykev »
£6 from any Honda Motorcycle dealer :thumbup:
Like what you do
Do what you like
thomas111
Re: airbox foam
Post by thomas111 »
Thanks guys my dad is giving me the filter stuff he uses to replace his lawnmower sponge
