Cleaning swing arm
BrianC
Cleaning swing arm
Post by BrianC »
As I'm stripping the back of my storm it seems a good time to give the swing arm a full clean - having said that I am not planning to take it off.
So what's best way to clean if up
Thanks
Re: Cleaning swing arm
Diesel works great .
While your at it clean and grease the linkage bearing
carmanbikes
Post by carmanbikes »
WD 40 I use
firestorm_al
Post by firestorm_al »
carmanbikes wrote:WD 40 I use
for degreasing I use surfex hd from bilt hamber, fantastic stuff and friendly to the environment, so even the tree huggers can do one.... :lol:
as mentioned before, check the lower suspension linkage, and re-grease if needs be.
Have you got a photo of after it had been cleaned Marty? :lol: :lol: :lol:
Duffy1964 wrote:Have you got a photo of after it had been cleaned Marty? :lol: :lol: :lol:
ha bloody ha, it was minging before..... :lol:
BrianC
Post by BrianC »
Is that an abba bike lift I see there?
Looks like it pivots on the swinging arm bolt?
Reason is I have one arriving tomorrow !!!!!
kev64
Post by kev64 »
I just done mine, used gunk and worked in with a toothbrush.
Then I went a step further and got all the paint off the smooth bits and polished it up.
Looks ok
:D
that's an abba stand mate, yup it pivots on the swingarm bolt, I also have a rear lift arm, which raise's the front wheel, a very handy piece of kit, it made painting the forks a real doddle.... :thumbup:
BrianC
Post by BrianC »
When the lift arrives I will be stripping that pesky rear suspension and checking it out
Tricky then to remove swing arm with the abba stand to get at the linkages... you'll have to wedge it up and use engine mounts or...
BrianC
Post by BrianC »
I wasn't going to take the swing arm off, unless there appears to be wear. I should be able to get all the other linkage off using the abba stand?
a bit of g101 and a toothbrush does the job :thumbup:
maggot
Post by maggot »
WD40 works great and leaves a protective layer to boot
