Ebay Finds (unusal/cheap/rare/or just good value)
Moderator: VTRDark
Re: Ebay Finds (unusal/cheap/rare/or just good value)
http://pages.ebay.com/link/?nav=item.vi ... 51&alt=web
Bloody cheap set of late clocks, if anyone is looking
Still log on bud just quiet, since I went back on Facebook after I couldn't find a decent gsxr forum I've done most my posting on a gsxr k5 k6 page, much prefer a forum tho full of wombles idiots that Facebooklloydie wrote:Decking hell Seb where you been ?
Lube, no lube, it's your choice .
Good to know your still around mate .
http://www.ebay.co.uk/itm/Honda-VTR-100 ... 6016.l4276
There like buses you wait ages then 2 turn up at once...
Not mine...fairly cheap but no under pics so you wont know if the tap & gubbins is still fitted.
"Complete with level sensor and fuel tap but fuel cap not included"MacV2 wrote:http://www.ebay.co.uk/itm/Honda-VTR-100 ... 6016.l4276
Helps if you read the description
True but I had no intention of buying it so didn't read it...bald_pig wrote:"Complete with level sensor and fuel tap but fuel cap not included"MacV2 wrote:http://www.ebay.co.uk/itm/Honda-VTR-100 ... 6016.l4276
http://www.ebay.co.uk/itm/Honda-VTR-100 ... 6016.l4276#
a lot of bike for the money, terrible advert tho.
Honda VTR1000 Firestorm 2001 Exhaust System Two Brothers Silencers
http://www.ebay.co.uk/itm/Honda-VTR1000 ... 51d157ceee
Now that is seriously tempting me even though they are carbon.Honda VTR1000 Firestorm 2001 Exhaust System Two Brothers Silencers
Is it a whole system Carl?cybercarl wrote:Now that is seriously tempting me even though they are carbon.
Also seen this, not too sure what this is off though
http://www.ebay.co.uk/itm/Honda-Vtr1000 ... 41967317b0
They are from an SP. The Oval pipe at the cylinder end is a give away. Tony may be interested in these though as he's has is oval porting project.
The TB cans/pipes are bit too bashed up for my liking on closer inspection.
Interestingly although the port looks oval, it's actually a round port and pipe end, but then both the port and the pipe end are partially filled in to speed up the exhaust gases exiting the port.
The experiment Carl is referring to is meant to replicate this, as I can explain some of the horsepower differences between the tw engines but there is a missing 5bHp or so, and I think the port work is what makes the difference. But I'm dependent on a skilled machinist to do the work, and he's been very busy, so the project has stalled at the moment.
The pipe diameter is larger than a Storm one, though, and so with a pipe of the Storm's standard diameter it may well be that the restriction would obstruct flow to a detrimental level, whereas the larger diameter SP pipe NEEDS restricting at that point in order to get gases out of the exhaust port efficiently.
Fascinating, innit?
Fascinating, innit?
Yep it is indeed. Thanks for the info Tony.
So it's not just Any Port in the Stormtony.mon wrote:Interestingly although the port looks oval, it's actually a round port and pipe end, but then both the port and the pipe end are partially filled in to speed up the exhaust gases exiting the port.
Fascinating, innit?
Hmmm, Yes....Duffy1964 wrote:So it's not just Any Port in the Stormtony.mon wrote:Interestingly although the port looks oval, it's actually a round port and pipe end, but then both the port and the pipe end are partially filled in to speed up the exhaust gases exiting the port.
Fascinating, innit?
perhaps.
By the way, they won't fit a Storm without mods to the sump. Another game I have to play at some stage, got the Sp1 sump and need to cut and shut it onto a Storm upper section but then modify the oil pump strainer to suit. It will need shortening and fitting a swan neck.
That allows me to run the front downpipe "through" where the Storm sump currently is, and keep a larger diameter downpipe but without intervening on lean angle.
