Just ordered this...
... Nitron goodness!!
http://www.nitron.co.uk/catalogue_item. ... odID=74153
can't wait, should complement the Rogered forks beautifully!!
Insurance: Bennetts CH24823B Exp 21/07/17
Mot Exp: 22/05/2017
Tax Exp: TBA
Mot Exp: 22/05/2017
Tax Exp: TBA
Re: Just ordered this...
Very nice [SMILING FACE WITH HEART-SHAPED EYES]
yep should be good,i baught the base moble and its much better than standard.
I have been running the same one for 2 years and very pleased with it. quality bit of kitcountrymick wrote:yep should be good,i baught the base moble and its much better than standard.
- carmanbikes
You will have to keep us updated on how it performs
very nice. With your uprated forks by Roger Ditchfield, and the new shock, that should make a BIG difference in the handling department
I agree, I run a rogered forks and an ohlins shock, you can't even compare them to the standard setup, just so much better....sirch345 wrote: very nice. With your uprated forks by Roger Ditchfield, and the new shock, that should make a BIG difference in the handling department
- bigtwinthing
Yep i had Rogered forks and a WP rear shock. Made a world of difference.
Fitted the shock now, but not test ridden yet. I'm trying to find a neat solution for mounting the reservoir, currently its just resting on top of the battery. I've got some alloy short stacks to fit too, so I'll be epoxying up a slide hole in a pair of my spare carb slides and fitting those at the same time as sorting the reservoir and fitting my longer sidestand courtesy of MacV2, then I think I'm done apart from service stuff for the next year (hopefully).
So far we have:
Rogered Forks
Dunlop Qualifiers
New steering bearings
Valve clearances done
MCCTs
Carbs Ultrasonic cleaned
Hawk8541 carb mods
Extended carb balance lines
TPS set
New OE air filter
New oil/filter
New Chain and sprockets
Nitron RP2 shock
Alarm removed(faulty)
Waterpump rebuilt
Cooling system flush and new coolant
Various bits powdercoated
But it's still TEAL!!
So far we have:
Rogered Forks
Dunlop Qualifiers
MCCTs
Hawk8541 carb mods
TPS set
New OE air filter
New oil/filter
Nitron RP2 shock
Waterpump rebuilt
Mot Exp: 22/05/2017
Tax Exp: TBA
Mot Exp: 22/05/2017
Tax Exp: TBA
Sounds like your good to go [THUMBS UP SIGN]
Get your new shock dialled in to suit you, and you'll have a very good handling Storm
