Struggling to sync carbs
Seeker 77
Post by Seeker 77 »
This is the very strange problem I am having. I was trying to sync the carbs because I get these coughs when I am riding. Completely miffed by what to look at
Re: Struggling to sync carbs
Ha ha you have to have the air box fitted and set the idle to 1800rpm
Seeker 77
Post by Seeker 77 »
Ah, the instructions don't mention that bit!
mellis wrote:Ah, the instructions don't mention that bit!
What instruction are you following ?
Seeker 77
Post by Seeker 77 »
The ones by AMCQ. As a matter of interest why doesn't it run without the air-box? My KTM and GSXR ran fine without it!?
carmanbikes
Post by carmanbikes »
The problems your having sound like normal, Carb Fart ha ha
Seeker 77
Post by Seeker 77 »
lloydie wrote:Ha ha you have to have the air box fitted and set the idle to 1800rpm
Not according to these:
i get the same reading with the airbag off and on, so I say it doesn't matter.
I will have a look at the youtube and see what i can see
well its not happy to idle! were there flames coming out of the carbs? I kept seeing little flashes from the front carb when it made the noise.
could just have been the slide opening and the glint of the brass needle, but looked weird
looked again and defiantly flames..... you need to check the valve clearances as it looks like the combustion is leaking back into the inlet
Seeker 77
Post by Seeker 77 »
This is what I feared.... I'm not worried about doing clearances, im more worried that this "9000 mile" bike has done far more.
mellis wrote:This is what I feared.... I'm not worried about doing clearances, im more worried that this "9000 mile" bike has done far more.
Now I don't want to be at all negative, but one other possibility is that it's had a cct fail and the front inlets are slightly bent, closing up the clearances.
But on a positive note, if so that might mean that the mileage is genuine.
It's not a big one to fix, even if all four need replacing on that head, and I have valves if you need some. Just a head gasket to buy, plus some shims.
bigtwinthing
Post by bigtwinthing »
Give it a compression test to start with.
Seeker 77
Post by Seeker 77 »
Took the opportunity to remove the PAIR while it was all apart, that did nothing. Haven't got time to do a compression check and valve check this weekend, might take it on over Christmas leave. I find it very hard to believe that it's anything as serious as that, it runs well when it gets going and has plenty of top end. It just runs sh1t off a closed throttle when cold. I will put up with it for now until I get the time and motivation
Did you block up the little pipes from the carbs to the pairs ?
