Nah it wont roll past you. The nut will work loose & fall off & some miles later if the spindel moves it will fall out on one side only the wheel will turn & jam..locking up the rear in a huge skid. Chances are you wont hold it & will either low side or go straight on depending on spedd at time of lock up, angle of lean ect. Lets just hope its not on a mountain switch back with no barrier & a 1000' drop...Kev L wrote:Good point, well presented old chap.agentpineapple wrote:not if it rolls past me because I forgot to do the rear spindle nut up properly
Now if the wheel fails...expect the same result...
