A bit of a cheeky question this one because it's not on my FireStorm but on my 1993 CB1000 Super Four but I guess the same would apply to a Storm as it's a bit of a generic question
My fan doesn't appear to be coming on - I changed the original fan switch when the fan stopped working, fitted a cheap Chinese replacement which worked initially but stopped working soon after. I suspected the Chinese factor and kicked myself for going against my better judgement and buying anything Chinese! I replaced the fan switch next with a decent Japanese switch, which worked initially and stopped working soon after!! grrrrr!
I have checked the fuse which is okay. taken the fan off and connected it to the battery and it runs fine and is clean and as new and runs smoothly, the wiring also looks in good condition and no obvious signs of corrosion. The bike is in almost showroom condition, so I don't suspect any general corrosion related issues
Coolant levels are fine
Any suggestions or advice would be greatly appreciated
Fan?
Re: Fan?
Sounds like the bikes had it, if your fan switch is broke then it's time to break the thing.... On that note I'd really like the forks, yokes and brakes, will you sell them to me
I would suggest some sort of wiring fault, maybe a short somewhere, or possibly the fan motor is intermittently sticking and causing the troubles. you could wire up a handlebar switch to operate the fan manually, not ideal but it will get round the problem.
- bazzashadow
Re: Fan?
can he heat his switch with a blow torch to test it malc
Re: Fan?
The temperature switch just completes the ground connection from the fan motor. With ignition on, the power supply through the fuse to the motor and then to the switch should show 12v with your meter between the female terminal on the wire, and a ground like the frame. You should be able to connect a wire to that female terminal and touch it to the frame and the fan will start. If not, you have a wire problem between the battery and the temperature switch. If the fan works when tested as above, then your switch might be dodgy.
Edit: Better still, look at section 19-12 in the service manual. A better description of what to do than mine!
Re: Fan?
Thanks for all your help guys - I will do a voltage test on the wiring and if I can't get over the problem, I might try a [fan] switch on the handlebars
It's something I need to get sorted as I live in Spain and the old CB has no engine cooling fins, I also get caught up in traffic at the Spanish/Gibraltar border crossing most days - so it needs to get sorted sooner than later
Thanks again
Thanks again
