At what ?tony.mon wrote:Apart from that, is it any good?popkat wrote:Feckin tyre slime shiteLet the air out then break the bead and get covered in the stuff as it explodes out of the tyre, takes ages to clean up the wheel and tyre machine, uses loads of blue roll and I can't dispose of the tyre with the stuff in it...
You try and educate people not to use the crap stuff but they insist on putting it in even when I show them all the corrosion it causes to their wheels. Todays one had deep black corrosion all around the tyre valve, had to chip it off, rub it down and paint that area. the last one I did corroded the rim so bad it was leaking out of the bead, so much for the stuff keeping your tyre inflated...
I will never sell it !!
As a tyre sealant I wouldn't know, never used it.
For abstract art It's quite good judging by the spray pattern over me and my Firestorm that was parked just behind me, got to clean it off the bike yet, Jackson baldrocks.
