Carb slides
Carb slides
Hey guys i cant remember where i heard this and not sure if it is true but r the carb slides different for front and back ? if so how can you tell and what r the symptoms if they r in the wrong way
Re: Carb slides
Same front and rear .
Re: Carb slides
Jets different, slides the same IIRC
Re: Carb slides
taught what was a strange thing alrightMav617 wrote:Jets different, slides the same IIRC
mmm bike isnt running well like the slides r not rising . carbs were cleaned and synced , all pipes r in place on airbox . it just has no power barely get 70mph out of her
Re: Carb slides
Have you checked the diaphragms are installed properly?
Re: Carb slides
Have you done anything else to it latley...like install new CCT's ?
As that sounds like the timing is out !
Re: Carb slides
Make sure both slides return the same, theres a video somewhere, including the sound they make !!ConTRo13R wrote:Have you checked the diaphragms are installed properly?
Re: Carb slides
ill check them again the spings r very long and it was tricky alright gettin that closed up .ConTRo13R wrote:Have you checked the diaphragms are installed properly?
Re: Carb slides
just full service . i have the manual ccts there ordered them from a gent from this site havent installed them yet . ill be checkin the timing after install was plannin on doing the valve clearances at the same time as i only have the bike short time and have no clue on her history , 27k miles on the clockMacV2 wrote:Have you done anything else to it latley...like install new CCT's ?
Re: Carb slides
any idea where to find that videokev64 wrote:Make sure both slides return the same, theres a video somewhere, including the sound they make !!ConTRo13R wrote:Have you checked the diaphragms are installed properly?
Re: Carb slides
went looking on youtube and i think it maybe the diaphragms when i start it with with airbox open my slide r totally stationary i noticed in few youtube vids there lads with aix totally off and the slides pulse , so maybe mine r not pulling out properly while driving
Re: Carb slides
There you go.
Take your time with the diaphragms, what I do is have the rubber diaphragms rolled down over the slides and then rest then in the carbs with themy seated in position then I wedge a pexcellent of cardboard into the venturi to stop the slides fully going in (but in enough that the needle is in the emulsion tube. Then take the black cap a wedge the spring in leaving an inch or so hanging out and hold with a finger between the spring coils, use this a your guide to getting the spring into the slide. Then once the extra inch is in the slide so it just yourealised finger between the slide and the cap use your ninja skills let the spring go and push the cap on to the slide. Slowly remove cardboard from venturi whilst pushing the cap down. Now hover the cap half a cm or so above the diaphragms seal and have a good look to make sure she is sitting nicely in the groove. Adjust if necessary. Then push cap fully on and bolt down. If that even makes any sense at all.............
Re: Carb slides
Can you push the slide up into the Carb fully?addicted to rage wrote:went looking on youtube and i think it maybe the diaphragms when i start it with with airbox open my slide r totally stationary i noticed in few youtube vids there lads with aix totally off and the slides pulse , so maybe mine r not pulling out properly while driving
Re: Carb slides
they do indeed . i have manual cct to fit so ill tear her right down again the workshop spot currently has my poor zrx in it so she will get the tlc first . ill let yis knowtony.mon wrote:Can you push the slide up into the Carb fully?addicted to rage wrote:went looking on youtube and i think it maybe the diaphragms when i start it with with airbox open my slide r totally stationary i noticed in few youtube vids there lads with aix totally off and the slides pulse , so maybe mine r not pulling out properly while driving
Re: Carb slides
cheers sounds like u have done this a few times. i have worked on loads of sets of carbs but never have i seen a spring liek the one in the vtr is madnessConTRo13R wrote:There you go.
