Think it's dead
domdom
Think it's dead
Post by domdom »
Hello all got bit of a problem. After filling up, bike wouldn't start, AA about as much good as tits on a fish...... Any way replaced RR coils and plugs. Turns over fine just no spark. Any ideas help would be much appreciated
Re: Think it's dead
VTR1000F (Superhawk) Firestorm Service Manual PDF > http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=18025
domdom
Re: Think it's dead
Post by domdom »
Thanks wicky, just ordered icm as pretty much been though that list...... if that don't fix it, your all welcome round for bonfire :lol: :lol:
Re: Think it's dead
Hold on is this not a fuelling issue. Tank breather, tank ventilation issue, Vapour lock from overfilling possibly. Are you sure it's not sparking or maybe there are two issue happening at the same time here. I have a feeling you may be barking up the wrong tree. It no good throwing money at parts in hope that is maybe. Diagnose where the problem is then change or fix the required parts.
http://www.vtr1000.org/phpBB3/viewtopic.php?f=7&t=17803
domdom
Re: Think it's dead
Post by domdom »
Quit sure it's not fueling problem, as it happened at pump, also drained half the fuel out when got home made no difference. Defo no spark even tried new plugs today. Put old sheet over me and bike just to make it as dark as possible, not a thing .
Re: Think it's dead
I take it the bike spins cranks over OK then. Sidestand switch is a common failure. You may want to bypass that by joining the two wires together to rule it out. When you changed the coils did the HT leads get changed too or did put stick coils on?
domdom
Re: Think it's dead
Post by domdom »
Yep she turns over like a good'un, changed the HT leads when got coils, just joined Sidestrand wires together, unfortunately made no difference..... ouff
VTR Phoenix
Re: Think it's dead
Post by VTR Phoenix »
You didn't put diesel in by mistake? Has this happened before? Any strange/warning signs before it happened?
domdom
Re: Think it's dead
Post by domdom »
Just been and checked defo got petrol in tank, only thing that happened was had to jump it that morning, but fired straight up got to garage filled up and nowt. Turned over put didn't start.
VTR Phoenix
Re: Think it's dead
How did you jump it? Maybe blew the ecu. You have a spare to check?
domdom
Re: Think it's dead
Post by domdom »
Off the car, that's what I was thing after replacing most of the other stuff, should have one Thursday all being well.
Re: Think it's dead
VTR Phoenix wrote:You didn't put diesel in by mistake? Has this happened before? Any strange/warning signs before it happened?
How would that stop it sparking!?
VTR Phoenix
Re: Think it's dead
Was going by most recent posts, see above regards fueling problem and CC post. I've had a long day and missed some posts. Is it such a bike issue? It happens
Hamrammr
Re: Think it's dead
Post by Hamrammr »
I once had the same problem on a CRM 250 Mk2 I used to own. If you use the kill-switch to stop the engine flick it on and off a few times to check if that's not your problem. You can also open the kill-switch housing and spray it with electrical contact spray just to make sure.
VTR Phoenix
Re: Think it's dead
Hamrammr wrote:I once had the same problem on a CRM 250 Mk2 I used to own. If you use the kill-switch to stop the engine flick it on and off a few times to check if that's not your problem. You can also open the kill-switch housing and spray it with electrical contact spray just to make sure.
If the kill switch is the issue it wouldn't even turn over.
