RPM. I idle at 1000 RPM and drive at 2300 mostly is it bad?
RedStormJ
Re: RPM. I idle at 1000 RPM and drive at 2300 mostly is it b
Post by RedStormJ »
I assure you guys it has none... I am not sure how a bike could soft limit with carbs as Fi cuts some fuel. Hard limit is an obvious sound. I tried it out again before work on my only straight.
Still having trouble staying over 3k takes pratice but I guess it feels smoother. My big problem is my blipping the throttle and getting back on it in first as if im not careful tire slides. I also think tires are hard so change is due.
