I l ran my fuel tank dry
Last night coming home with the low fuel light getting brighter i very nearly made it to the garage before the bike cut out.I pushed it to the pump,and filled up with 97 octane,restarted and rode on,but after a mile and a half got power loss,and the engine stopped again.I thought i might have to push the bike home the last mile, but after a minute or two gave it another go on the starter button and she started,but was down on power.I got almost to my door and the engine cut out again.Has anyone experienced this? I imagine some residue from the bottom of the tank has been sucked into the carbs and blocked them,but is there a filter between the tank and the carbs that I could check first? Any advice appreciated.Les Graham.
Re: I l ran my fuel tank dry
Odd - Theres a filter inside the tank where the fuel tap connects to the tank.
http://www.bike-parts-honda.com/moto-ho ... 11510.html
http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=18025
Was the "97 octane" super unleaded? Run it through and fill up with normal unleaded. And charge the battery up as the multiple restarts could have drained the battery.
yes
once after filling road a mile or so and the bike spluttered to a stop. opened the petrol cap and there was a whoosh of air ... some how it had become vacuum locked . Sorted itself out then
- Furrybiker
Sorry I am not any help to you, but how much did the bike actually take to fill up?
I only ask as I dont really believe the 16 litre figure.
- KermitLeFrog
I ran mine dry (coasting into a petrol station) and filled up (to the brim) sitting on the bike. Got 16.5 litres in it.Furrybiker wrote:Sorry I am not any help to you, but how much did the bike actually take to fill up?
- KermitLeFrog
ps. It's a vacuum operated fuel tap. If the float bowls are empty it can take a bit of turning over to get enough fuel into the bowls to start up.
Blocked tank breather.
Same happend to me once...If it happens you get a vacume lock & it wont pull the fule through ...Sounds simple but just pop the cap open. Turn it over a few time to refill the carbs...StuartWags wrote:yes
- Furrybiker
Thanks, good to know that when the "red light of pushing" comes on I still have about a gallon!KermitLeFrog wrote:I ran mine dry (coasting into a petrol station) and filled up (to the brim) sitting on the bike. Got 16.5 litres in it.Furrybiker wrote:Sorry I am not any help to you, but how much did the bike actually take to fill up?
- KermitLeFrog
No, you don't. You have about 3 litres. Enough for a safeish 20 miles. I ran dry at 24 miles from the red light.Furrybiker wrote:Thanks, good to know that when the "red light of pushing" comes on I still have about a gallon!KermitLeFrog wrote:I ran mine dry (coasting into a petrol station) and filled up (to the brim) sitting on the bike. Got 16.5 litres in it.Furrybiker wrote:Sorry I am not any help to you, but how much did the bike actually take to fill up?
- Furrybiker
They must vary as I managed 20 miles with the light shining on the motorway before I got to a fuel station, it held same as it always does when I fill it asap when the light comes on, about 13 litres.KermitLeFrog wrote:
Thanks fellas,I shall in future head for the nearest petrol pump once the light comes on- I probably was pushing my luck trying to go more than 20 miles.The funny (lucky?) thing is that I have done nothing to the bike since last wednesday, and I gave it a run today and it is running ok again.So perhaps it wasn't sediment causing the problem, but vacuum or lack of it.A mystery to me, I'm just glad to have my VTR back. Cheers.
