Help with Electrics
kingbob
Help with Electrics
Post by kingbob »
Hi, Hopefully someone can help.
My VTR seems to have died. Tried starting it a couple of days ago, but it wouldn't fire.
Instead of draining the battery, I gave it a 5 minute rest and tried again.
Put key in, turned to ignition, and nothing, not a light, no power what so ever.
Took battery off, recharged it, tried again, still nothing, totally dead.
Anyone any ideas?
Bob
If you think you are right, or if you think you are wrong, you are right!
Re: Help with Electrics
Suppose you've looked at main fuse ?
kingbob
Post by kingbob »
Checked fuses under the seat, is there another?
Main fuse is integral with starter relay under seat cowling onthe left hand side.
If the reg/rec fails it will kill the battery stone dead.
kingbob
Post by kingbob »
Hi,
I'll check the main, thanks for the heads up.
Otherwise possible reg/rec replacements by the sounds of it.
Cheers,
Some one will be along with more knowledge than me to advise on which r/r to get.I unfortunately went the expensive way with a mosfet
Anyway welcome to the forum. It is also advisable to swap auto cct's for manual ones if it's not been done as they fail and bend your valves.
kingbob
Post by kingbob »
Cheers for everything.
Had the CCTs done when I picked up the bike, just in case.
Checked good old bay, they range from 60 quid to 15/20, bit of a range.
Trouble is, wont know if the batteries fried so may have to look at that too.
Ouch
VTR Phoenix
Post by VTR Phoenix »
Have you checked the battery with a volt meter to see if it is holding a charge?
Next check your fuses, take them out and physically check them.
If your rr has packed up it would not stop the bike turnng on and firing it will stop it charging or overcharge the battery.
Did you get any strange symptoms before this happened?
Had you been riding it in the rain prior to this happening?
bald_pig
Post by bald_pig »
Was the main fuse ok then? You may need to run over everything with a multimeter to see what's happening. You're not a million miles away from me, if you need a hand one weekend give me a shout.
hallie
Post by hallie »
Handy diagram here
easy to follow
If you can't view it let me know and I'll pm it
http://www.biker.ie/forum/attachment.ph ... 1336069244
TIP; Never take a sleeping pill and laxative on the same night
http://morrisonbhp.net/
kingbob
Post by kingbob »
All,
Thanks for all the assistance.
Not got to the main fuse today, a job for tonight.
As it happens, I was riding in the rain, and thoroughly enjoyed it too, not....
Baldpig, may pm you if I cant find the problem, thanks for the offer.
Hallie, I cant view the diagram, I'm not registered on the site.
Can you send it over.
Cheers all.
VTR Phoenix
In that case also check the spark plug hole on the front cylinder, they have a tendency to collect water and short the bike. Take off the plug cap to see.
hallie
Post by hallie »
