Brake seals
Brake seals
Hi guys,
Would you trust a brake seal kit from Wemoto or would you spend over double to buy the genuine Honda items?
Thanks
K :-)
Thanks
K :-)
Insurance: Bennetts CH24823B Exp 21/07/17
Mot Exp: 22/05/2017
Tax Exp: TBA
Mot Exp: 22/05/2017
Tax Exp: TBA
Re: Brake seals
Probably made in the same factory in China...
Re: Brake seals
Cool thanks
Mot Exp: 22/05/2017
Tax Exp: TBA
Mot Exp: 22/05/2017
Tax Exp: TBA
Re: Brake seals
Wemoto are very reputable firm. I have used them loads of times and I don't think they would sell anything they believed to be inferior. Postage is quick from them too
Re: Brake seals
Thanks for the recommendation. I'll get them ordered up next week.
Mot Exp: 22/05/2017
Tax Exp: TBA
Mot Exp: 22/05/2017
Tax Exp: TBA
- TheGingerBeardMan
Re: Brake seals
I recommend Wemoto as well. I have ordered loads of stuff in the past for Yams n' Hondas, and have never had reason to send anything back. The quality of aftermarket bits supplied by them is (to me) 99%. Yes, there might be slight differences in the finish (cheaper plastic moulding, and gaskets not fully trimmed (I've found that a few times), but that's rare thesedays.
As you've probably already seen on Wemoto, they have OEM part photos, and if they stock the aftermarket equivalent, they have a pic of that too. I don't always go for price saving, and a fair bit of stuff ordered is genuine Honda. More expensive, but just for personal piece of mind.
Dave Silver does pattern fork seals as well...
OEM fork seal £4.02 each (Genuine Honda) Dave Silver Genuine Honda fork seal
Aftermarket fork seal £2.34 each (Made by the same OEM factory, at a fraction of the price) Dave Silver pattern fork seal
Now - buying 2 aftermarket seals from him will cost a total of £8.22 (including P&P !)
TAX: 1st March 2017
MOT: 16th March 2017
INS: 14th March 2017
TAX: 1st March 2017
Re: Brake seals
When it comes to things like brake seals I prefer to stick with genuine Honda parts, although there is probably nothing wrong with some after market parts as others have said, it's your choice really,
- bigtwinthing
Re: Brake seals
MacV2 wrote:Probably made in the same factory in China...
fence sitter! answer the question
Re: Brake seals
iv used wemoto seals in mine and have had no problems
Re: Brake seals
For me, I would use OEM but either should work just fine.
The one thing I would add is the often over looked assembly fluid. Yes some brake fluid will work but there is a better way:
http://www.ebay.com/p/Brake-Fluid-Raybe ... /187971644
Use it once and you won't go back to just brake fluid unless it is an emergency.
