Bolt removal specialist
- StormyRob
I don't suppose any of you would know a bolt removal specialist in the south East? The front Bolt in the engine/frame is seized solid. Nothing will get it out and I don't want to end up damaging the frame or engine with more extreme methods.
Thanks.
Thanks.
Re: Bolt removal specialist
Just look for a local enginering firm Rob...
I doubt you'll get much joy serching Yell dot com for 'Bolt removal specialist'.
They can be a bitch to get out... I've done 3...
1st one came out with aplication of a large hammer & lots of effort...apart from the bolt being fecked no other damage.
2nd one I had to cut the git out...Damage to frame but was reused with a spacer...
3rd one slipped out no worries...
You need to soak the offending area with plus gas...not bloody wd40... Normaly the bolt rusts & seizes in the bit where it goes through the top mount on the motor...on the side with the spacer...
Put a nut on the end of the bolt to protect the thread a get medieval with the biggest hammer you have...Dont be shy you will need to bash the fecker !...Once you get it moving remove the nut & use a smaller diameter spindle to carry on with the hammer action...
- StormyRob
I had the bolt in the end. Been hitting it with a club hammer f@#@ING hard. You think I should get plus gas instead and hit it some more tomorrow?
maybe this could help. I am sure you will find some usage in future :-)
http://www.jonnesway.co.za/?product=12- ... act-driver
edit: for hex bolt, ring spanner and hammer punch to the other end never failed for me.
Yes Plus Gas is best...Or if you have the means heat...StormyRob wrote:I had the bolt in the end. Been hitting it with a club hammer f@#@ING hard. You think I should get plus gas instead and hit it some more tomorrow?
- StormyRob
Bought and put about a third of the can on it. Absolutely soaking. Will stick some more on early in the morning and then some more hammer time at lunch time.
- bigtwinthing
get some heat into it.
- StormyRob
I'll have to get one of those gas things then!
Use a heat gun to heat the metal around the bolt, mine goes upto 600 degree's. a good addition to the tool kit, they are cheap to buy and come in handy for other stuff too.
http://www.homebase.co.uk/en/homebaseuk ... 0wodwTIFQQ
heat and soak then hammer.... then repeat until it comes out
Thermite
[youtube][/youtube]
[youtube][/youtube]
- StormyRob
I'm just going to have to be patient. Wouldn't thermite be lovely
- Saintsman27
We all Santo know when you've blurted it out or
maybe you have by now![Thumbup :thumbup:](./images/smilies/icon_thumbup.gif)
Sometimes it's easier to hacksaw through the bolts at the frame adjuster junction to the engine boss, then, when the engine's out, remove the bits of bolt afterwards.
When installing the new engine and bolt just use a washer of equivalent thickness to the saw blade.
It works fine.
If the bits of bolt still won't come out you need to decide whether you need to save the old engine. Mostly people remove the old engine because of damage due to cct failure.
But if you still need to save it, cut sideways, along the length of the boss each side, and the bolt frees up.
Then get both bosses rewelded.
Although this sounds like a huge amount of work and expense it isn't, and saves spending days twatting it with a hammer getting nowhere.
I usually give up on day two and get the hlacksaw out.
What's a blurting tool, sounds useful?
It works fine.
Similar to a blurting fool, someone who makes unconsidered statements or replies, would be my guess! ![Laughing :lol:](./images/smilies/icon_lol.gif)
