Frame polishing
Bondy
Frame polishing
Post by Bondy »
Does anyone know what you need to polish your frame up and how to do it? My mates had his done and wanted to do mine while the bikes in the spray shop.
You want to speak to xxxrated, either PM him or put up a F.A.O.
Right I'm back again, forget the above, have a look at this link, at the 7th post down :!:
http://www.vtr1000.org/phpBB2/viewtopic ... hing+alloy
xxxrated
Post by xxxrated »
alot of wet and dry and about 3000 tubs of elbow grease mate lol.
basically you need to get yourself an assortment of wet and dry. i used
80
160
240
480
800
1200
1500
2000
its just a case of removing your fairings and sanding the frame down with the lowest grade and then moving up to the highest grade paper. to do the full frame (top and bottom bit) youre looking at an easy 30 hours work although its worth it in the end
xxxrated
Post by xxxrated »
Rincewind
Post by Rincewind »
do you need any sort of polish to be applied during the sanding or buffing it up??
Never argue with an idiot, they will drag you down to their level and beat you with experience.
xxxrated
Post by xxxrated »
i gave it a quick autosol after changing grades just to see how things were coming along. and be sure to use the wet and dry wet when you get up to 400 and above otherwise itll mark the surface
Bondy
Post by Bondy »
Thanks mate. I got about a week from when the fairin goes in till i get it back so ill try and crack on then. Yours looks awesome mate just hope i can get mine the same.
