I've a 99 Storm Ive had for about 2-3 years. I've noticed on the longer rides Im getting numbness in my right foot. obviously this would be down to a vibration, but what could it be to only be on the right side?!
DazB wrote: ↑Mon Jun 22, 2020 4:38 pm
Hoping one of you be able to help?
thanks
Daz
Sounds weird but make sure your carbs are balanced, causes all sorts of vibes...
Also make sure the all the bolts holding on the footrest are torqued up correctly...
I used to put a set of std cans on for the mot at first, they always made the rh peg buzz noticeably.
Never a problem with mids and cans, though.
If you have standard cans on, to check, just remove the bolt through the clamp by the peg and temporarily twist a bit of wire through the holes- then ride to test.
tony.mon wrote:I used to put a set of std cans on for the mot at first, they always made the rh peg buzz noticeably.
Nice, thanks. Hopefully I’ll grab some time in the garage this week and have a look. I’ll report back
Took a look at this at the weekend, and found the bolt connecting the pip to the footpeg was super tight and rounded out! so looks like it was an issues for the person before. Anyway, the rubber mounted was old and started to split, it was on so tight it was crushing the rubber. Ive replaced the the bolt, might need to replace the rubber but not until the rain stops and i can go on a long test.
fingers crossed.
It should have a top hat spacer in it to pevent the rubber being squashed...
