Clutchless shifting on VTRs
Anyone change gear without the clutch, after the 2nd shift?
Obviously only on the upshift.
I read on another forum that most sports bike riders do this most times they ride.
Something I never used to do, so tried it a bit yesterday, and it was fine, if not faster in the shift.
Any problems likely to occur with repeated clutchless shifting on the VTR??
- Fireman on a Storm
I've been doing it for years on all of the bike I've owned.
Not a great idea from 1st to 2nd but fine from there on.
Hold your foot under the gear lever with a bit of light pressure shut the throttle as normal and it will up shift as normal if not smoother.
You need to experiment a bit. You may find fully shutting the throttle may be too much.
You may only need to half shut the throttle when you are going a bit faster for the smoothest nd quickest gear changes.
Clutchless up shifts will not do any harm.
Down shifting without the clutch needs a bit more skill and if it goes wrong you will get some nasty sounds!
The idea is to down shift as normal with the foot but as you press the lever down a well timed blip of the throttle will see the gear slot in no probs. To learn this skill start at the lower end of the rev range. Brake slow down then change down!
With practice you will be able to change down without the clutch just as smooth as your up change.
A smooth clutch less down change will not harm the box either. Just make sure you learn the skill at lower revs
I learnt these skills form an ex 250 racer because I was struggling with the clutch due to a broken middle finger on my left hand.
IF YOU MISS A GEAR DON'T DAB THE GEAR LEVER AGAIN UNTIL YOU HAVE PULLED THE CLUTCH IN you will be in a false neutral between gears and may shift down 2 gears and lock a wheel, ALSO THE GEAR BOX WILL MAKE SOME COMPLAINING NOISES
I couldnt have read that before this weekend just gone, could I?Fireman on a Storm wrote:IF YOU MISS A GEAR DON'T DAB THE GEAR LEVER AGAIN UNTIL YOU HAVE PULLED THE CLUTCH IN you will be in a false neutral between gears and may shift down 2 gears and lock a wheel, ALSO THE GEAR BOX WILL MAKE SOME COMPLAINING NOISES
clutchless not crotchless , but by all means tell us more girlieVTRgirl wrote:I tend not to use the clutch if my left hand is busy with my pillion...![]()
However, I expect they have a clutch for a reason & if my left hand has nothing better to do, I'll use it.
just because your breathing doesn't mean your alive
