Not a happy bunny
obviously i could be wrong, but ive had same noise..and its always been cam end float''..its common' ish on twins''...most mehcanics(good ones) will tell u its not all bad, dont lose sleep over it..as i say ive had a couple of bikes with same problem...one of em 'i went on to do 40'000 miles with same knock,,,it boils down to the cam' floating slightly and thus knocks..if you want to have piece of mind, either go to a reputed mehcanic and explain the noise, and my theory or where are u based??? if local to me id happily confirm the noise
Stevie,bikerpiker wrote:Sorry for jumpin on the bandwaggon.....but..
Mines has got a squeek,yep, a squeek
Been like that since i bought it,can hear it when ticking over,or riding,the more revs,the more it sqeeks. Not too loud......but its there
Goin to nip down to Ayr soon to compare with Geordies engine.
Any ideas anybody
It's not your rear suspension that's seized or needs re-greasing by any chance I don't suspose Probably not, but may be worth checking out as they can cause a squeak, especially if not greased from new
- bikerpiker
chris....lee,,,,cheers lads,appreciate it
noise deff comes from engine ,but kinda hard to pinpoint where.Happens all the time whether im on the bike,or its sitting stationary,.
Noise is there both on the throttle,and backing off,both same loudness, but very,very faint...........but im sure i hear something
i might be wrong,and imagining things,but sometimes when u get something into your head ,its hard to shift
Really need to compare with another 'storm......
Im from hull mate but south yorks is only a rideawaylee67 wrote:obviously i could be wrong, but ive had same noise..and its always been cam end float''..its common' ish on twins''...most mehcanics(good ones) will tell u its not all bad, dont lose sleep over it..as i say ive had a couple of bikes with same problem...one of em 'i went on to do 40'000 miles with same knock,,,it boils down to the cam' floating slightly and thus knocks..if you want to have piece of mind, either go to a reputed mehcanic and explain the noise, and my theory or where are u based??? if local to me id happily confirm the noise
- LotusSevenMan
