Ba boom tish!!!
It's a very rusty Hypepro spring...The plate is for whaking Marty round the head with next time I see him...I'll sneak up on his blind side* & THWACK ! CLANG!cybercarl wrote:Aftermarket rear shock Mac, but what;s the metal plate all about by the rearset
* Nowt to do with his gummy eye, any angle of attack will do, have you seen his 'This could be your lucky day' glasses ?
- Pete.L
agentpineapple wrote:being in grain, it's to protect mac's 6th toe from the engine.......cybercarl wrote:what;s the metal plate all about by the rearset
PMSL
Just to be clear I do not have Six toes on either foot or six fingers on either hand I was not born in Grain so have no inbreeding issues.
I do have a massive growth between my legs but thats not an issue.
Anyway your just all jealous as the Wonky Donkey Storm came with this as well...
& these...
Ebay here I come !
& these...
Ebay here I come !
My bike overheated on me today......so fairing off and what do I see, my bloody coolant sensor wire hanging off. At least it was an easy fix with a quick squeeze on the crimper's.
Dibs on tool kit Mac if you want to sellMacV2 wrote:Just to be clear I do not have Six toes on either foot or six fingers on either hand I was not born in Grain so have no inbreeding issues.
& these...
Ebay here I come !
It is indeed & it's a faster colour than your Storm...
.I'd quite like the Storm that colour actually
Discovered a rattle from my motor when spinning higher than 6k rpm
Could my ccts need a wee tighten up? I've covered around 5k miles since installing them and also there doesn't seem to be any rattle when cold or on tickover...
Could do with checking my valve clearances too
Just wanna ride it now and check out all the totty, not cut me knuckles open in the 25°c garage
Jamie
I'd have said there'd be more camchain rattle when the engine is cold Jamie if its that!?
That's what I figured
Dunno what this could be. I might strip the cam covers off and double check chain tension, as I have given the ccts a 6th of a turn and it still rattles.
Jamie
Mine developed a rattle yesterday Between 4200rpm and 4500rpm on the way to work and it did the same on the way home ,
When I got home after riding it gingerly like I set the throttle to 4300 rpm and went over the bike to find it ,
I traced it down to the horn and swapped it for another one and all is good .
So Jamie it could be anything making it rattle so you need to trace it down before you start pulling it apart .
I did 25k on the old engine with no need to adjust the ccts
Agree. Check out the simple things first to probably save you some grief .lloydie wrote:Mine developed a rattle yesterday Between 4200rpm and 4500rpm on the way to work and it did the same on the way home ,
Yes good point dude, I'm just paranoid I guess. I need to check valve clearances so with check tension while I'm there.
Anyone else feel like sometimes, everything is a ferking chore?
Jamie
