Page 8 of 12
Re: AMQ46's storm
Posted: Fri Dec 08, 2017 9:43 pm
by AMCQ46
New front end conversion - the tricky bit....
fireblade yoke with Aluminium stem pressed out to be used for the conversion
top is the fire blade yoke where the donor stem was removed from
the black stem is from the Aprillia
the Fireblade stem now fitted to the Aprillia yokes
The workshop had to make a spacer that was a press fit on the Blade stem, then turn it down till it was the same diameter as the Aprillia stem, then they press fitted and glued that into the Aprillia yoke
Re: AMQ46's storm
Posted: Fri Dec 08, 2017 9:47 pm
by AMCQ46
The shopping collection
Sachs forks and yokes from a V4 Aprillia Tuono .. I used these as they are then correct length for teh firestorm, have radial brakes and they already have a top yoke that will take flat bars
The mudguard and the brembo calipers
Re: AMQ46's storm
Posted: Fri Dec 08, 2017 10:15 pm
by mik_str
can't wait to see the final product
Re: AMQ46's storm
Posted: Sat Dec 09, 2017 4:28 am
by lloydie
Going to be a great mod
you’ll love it
Re: AMQ46's storm
Posted: Sat Dec 09, 2017 7:48 am
by agentpineapple
Looking real good Al.
the makings of probably the best front end swap, seeing as the forks are the correct length....
Re: AMQ46's storm
Posted: Sat Dec 09, 2017 8:57 am
by Varastorm
Re: AMQ46's storm
Posted: Sat Dec 09, 2017 9:54 am
by fabiostar
im feeling major love for your front end Al
... its gona look proper trick when its done.
Re: AMQ46's storm
Posted: Sat Dec 09, 2017 10:06 am
by Varastorm
fabiostar wrote: ↑Sat Dec 09, 2017 9:54 am
im feeling major love for your rear end Al
... its gona look proper trick when we've done.
All fixed Fab
Re: AMQ46's storm
Posted: Sat Dec 09, 2017 10:13 am
by AMCQ46
Varastorm wrote: ↑Sat Dec 09, 2017 10:06 am
All fixed Fab
he takes it both ways .. the little tart
Re: AMQ46's storm
Posted: Sat Dec 09, 2017 11:34 am
by AMCQ46
the front wheel .. which I though was a forged OZ wheel, but it isn't, its a cast copy of the newer bikes
then I put the new bearings on the stem and got a bit carried away to see what it might look like on
locksteps look like it might be easier than I thought. I will put a block onto the bottom of the lower front fairing mount, and it will hit the existing stops on the aprillia yoke.
AMQ46's storm
Posted: Sat Dec 09, 2017 12:10 pm
by lloydie
Just wait tilll you try the ignition barrel
never had one on mine .
You really need to get them rsv wheels on the scales as some are lighter than others but all look the same .
I still like the brembo spoked wheels
Re: AMQ46's storm
Posted: Sat Dec 09, 2017 2:53 pm
by fabiostar
proper looking FRONT end (ya coonts lol)..
thats disc bolt pattern how close is it to the honda wheel??
Re: AMQ46's storm
Posted: Sat Dec 09, 2017 4:07 pm
by AMCQ46
fabiostar wrote:proper looking FRONT end (ya coonts lol)..
I will check tomorrow Rob , but there is very little dish on these discs
Re: AMQ46's storm
Posted: Sat Dec 09, 2017 5:07 pm
by agentpineapple
will you need to move the rads back Al?
I had to when I had the 954 front end, otherwise the lock to lock steering isn't very good. gold usd will always look sexy as hell. just don't go rear ending anyone again, Fabio said he was sore for weeks.....
Re: AMQ46's storm
Posted: Sat Dec 09, 2017 10:18 pm
by Varastorm
That looks really nice, In fact it looks nicer than really nice. Top job
