Page 730 of 1529
Posted: Wed Sep 03, 2014 7:26 pm
by tony.mon
Another little dyno run this AM, to establish what difference the high comp pistons make.
Posted: Wed Sep 03, 2014 7:30 pm
by lloydie
Two runs in the AM suppose you had to do two one for each cylinder ha ha
Posted: Wed Sep 03, 2014 7:57 pm
by lloydie
Come on then tony do tell how it went ?
Posted: Wed Sep 03, 2014 8:27 pm
by TravisZack
I took it down a notch on the preload and adjusted the damping slightly, got a bit more confidence back now. It was feeling a bit awkward lately, but I've lost just over 2 stone in the past few months so must finally be feeling the difference
Posted: Thu Sep 04, 2014 5:36 pm
by lloydie
fitted new wheel bearings and dust seals ,tweaked the bars now its ready for a play tomorrow if the knocking has gone .
Posted: Thu Sep 04, 2014 5:38 pm
by lloydie
TravisZack wrote:I took it down a notch on the preload and adjusted the damping slightly, got a bit more confidence back now. It was feeling a bit awkward lately, but I've lost just over 2 stone in the past few months so must finally be feeling the difference
loosing weight is always good for riding , i just need to sort myself out now even tho ive lost 1/2 stone in 2 weeks
Posted: Thu Sep 04, 2014 7:06 pm
by VTRDark
Running out of fuel and pushing the bike is good for loosing weight.
Posted: Thu Sep 04, 2014 8:53 pm
by tony.mon
lloydie wrote:Come on then tony do tell how it went ?
Quite well, considering.
It's worth doing.
I recommend it.
I really do.
Posted: Thu Sep 04, 2014 9:07 pm
by lloydie
I will be :-)
Posted: Thu Sep 04, 2014 9:25 pm
by tony.mon
You want real data?
Ok, last time on the dyno I observed that after the bike had bounced off the rev limiter for a few seconds there was a fair bit of blue smoke coming out of the exhausts.
But now, with a light hone, and new pistons/rings, there ain't none at all!
So the money spent on pistons and rings should be recouped in 25.7 years in less oil used.
Assuming that they don't wear and start leaking again.
But then new rings would have gained a bit, so perhaps the pistons aren't needed at all, just the new rings and a hone.....
But it gained 7Bhp and 4 torque, seems good vfm.
I'll gasflow the heads at some stage but ran out of weekend this time.
Also fit oversize inlets- can't hurt much.
Oh, and get the ram air tubes finished, and fit a new chain/sprockets, etc, etc, etc.
But I can't do much this weekend as I am acquiring another metal shed for Mon Acres.
More spares storage...
Oh, and I've bought another bike.
Only 650, but hey.
Posted: Thu Sep 04, 2014 9:34 pm
by lloydie
7+4 sounds like a good boost in power to me .
Thanks for the update tony
Posted: Thu Sep 04, 2014 10:40 pm
by VTRDark
Nice one Tony
Are you going to update your dyno thread. I ear wat your saying with the rings. I wonder what difference you would have had if only doing the rings, no pistons....or maybe go overbore standard compression.
Have you got any plans to sort out the bottom end risibility, balance things out a bit, as all your plans are going to turn the bike into a race/track bike. Cams!!!
How's your fulling doing now.
Posted: Fri Sep 05, 2014 5:27 am
by bigtwinthing
Got the bike in a nice position in the "garage". Bloody hell its a joy being able to fully walk round it.
Not sure about whether to plumb in the airline and water until i get the hyd lift in etc! Thats a luxury but wanted item. I have fitted the alarm.
Basic 12v car batt with a horn with micro switch hidden but it works a treat. If that doesn't work the "Westie will piss on there legs anyway!!!
leathers and helmets all stored nicely in there heated wardrobe. And both Gloves Jamie! Ski,s are in and Tools in the Van Vault bolted to the floor.
I am a happy Bunny.
Posted: Fri Sep 05, 2014 7:07 am
by Virt
bigtwinthing wrote:
I am a happy Bunny.
Do you consider it a disadvantage being a rabbit? How do you cope with everyday human tasks without hand-like appendages or opposable thumbs? How do you keep in control of the bike when you surely can't reach the controls?
If you could, would you want to be a human?
Posted: Fri Sep 05, 2014 10:08 am
by VTRDark
That would depend on who's hands it's in.
