You were lucky to get away without a blow out Macster
Must try harderDuffy1964 wrote:You were lucky to get away without a blow out Macster
fitted over sized pistons and balanced carbs bringing it to about 180bhp
What you smoking matechric wrote:fitted over sized pistons and balanced carbs bringing it to about 180bhp
Another delusional red owner Watty. One day they'll learn!!!
They slow to learn, then again, red ownersKev L wrote:Another delusional red owner Watty. One day they'll learn!!!
I polished the ports aswell makes oil glide through them better in mid range
fitted new titanium bolts saves weight and can keep eating more chips to balance it out.
And fitted nitrous for when i do bit of street raceing tops out about 190mph now
come on sounds better than i waxed it
OhWicky wrote:chric wrote:fitted over sized pistons and balanced carbs bringing it to about 180bhp![]()
Suppose it does matechric wrote:I polished the ports aswell makes oil glide through them better in mid range![]()
And fitted nitrous for when i do bit of street raceing tops out about 190mph now![]()
come on sounds better than i waxed it![]()
- agentpineapple
Marty if the one on the left is your idea of a lovely lady...it explains your poor taste in bike colours...
Oh hang on what's that she's sitting on...
Is that the only pic you could find of lady's sitting on a blue Storm... ?
- agentpineapple
I did a little tinkering today, ultrasonically cleaned a pair of oem front brake disc's, also my givi rack was looking tatty, so I stripped the paint off, down to the bare metal, cleaned it up, etch primed it and started to give it a coat of hammerite satin black, I forgot what a pain it is to use hammerite.
but done properly the finish is very good, I also re-lacquered a pair of mirrors that have been hydro dipped in carbon effect.
I 've also been struggling to try and drill out a couple of stubborn bolts, even using dewalt extreme drill bits and moly slip, I can't get the buggers out, I might have to take them to a garage to get them removed....
Which bolts is that mate?I 've also been struggling to try and drill out a couple of stubborn bolts
