Ckennedy wrote:Attempted to bleed to rear brake on the T to no availbut got the belly pan fitted and a 15 tooth front sprocket and even managed a very quick 12mile test ride
oh it was good, bring on better weather
Sounds like chuckle brothers !!AMCQ46 wrote:got new brake pads to replace the rears on me old bike which are making a horrid scraping noise and not much slowing down!!!! but because the new ones are top spec, I decided they could go on the front of my good bike and then the ones from there could go on the back old bike.
in case this is confusing you on how the back and front pads could be interchangeable, I should explain that this is on push bikes
Tsk ! I sent you a Acme battery strap yonks ago...(part of the prize for winning 'Spot the Difference' comp...)agentpineapple wrote:swapped batteries over, pain in the butt, I forgot how tight a fit the larger battery was, I still can't believe there isn't a simpler method of attaching batteries to vehicles, especially in this day and age.....![]()
checked my tyre pressures, F28/R30.....that's after 9 weeks of hibernation.
they're now F36/R42......![]()
chain lubed as well.
still can't be arsed to wash it tho.......
