Page 10 of 13
Re: Hi from Reading
Posted: Wed Feb 08, 2023 5:55 pm
by Commando77
No you didn't, it was slipped in there by the workshop fairy!
Re: Hi from Reading
Posted: Thu Feb 09, 2023 11:08 pm
by purgeraptor
Commando77 wrote: ↑Wed Feb 08, 2023 5:55 pm
Re: Hi from Reading
Posted: Wed Feb 22, 2023 4:37 pm
by purgeraptor
Fitted a radial M/C from a Kawa Z1000SX today, with new Venhill brake lines and fresh fluid.
Was going to fit a braided clutch line, but ran out of brake fluid...so that'll be tomorrow's job
Re: Hi from Reading
Posted: Wed Feb 22, 2023 8:22 pm
by tony.mon
Don't expect any difference after fitting a braided clutch line.
With brakes the line has to stand high pressures without ballooning, but the clutch line simply moves fluid from the master to the slave, so doesn't build up any pressure. Looks better, though.
Re: Hi from Reading
Posted: Wed Feb 22, 2023 8:55 pm
by sirch345
purgeraptor wrote: ↑Wed Feb 22, 2023 4:37 pm
I'll be interested to hear your opinion on the radial M/Cyl when you get out on the road
Re: Hi from Reading
Posted: Thu Feb 23, 2023 8:42 am
by purgeraptor
Will do Chris
Re: Hi from Reading
Posted: Thu Feb 23, 2023 8:47 am
by purgeraptor
tony.mon wrote: ↑Wed Feb 22, 2023 8:22 pm
Agreed.
Doing it mainly to replace the 22 year old rubber line, but it will look a little better too
Re: Hi from Reading
Posted: Thu Feb 23, 2023 2:45 pm
by purgeraptor
HEL clutch line fitted. Was a spare from my old Hack ZZR11 which blew its gearbox a few years back.
Bled fine with my compressor-powered quick bleeder thing.
Next job probably a braided rear brake hose.
Have also bought a black 'replica' clutch lever on eBay to match the black Z1000SX front brake lever.
Will only fit it if it's not junk quality, but at £12 delivered, it probably will be
That's it all done until I get to ride it, unless anyone can think of anything else worth doing?
Re: Hi from Reading
Posted: Thu Feb 23, 2023 9:30 pm
by sirch345
Good work with the replaced clutch line
Re: Hi from Reading
Posted: Thu Feb 23, 2023 10:21 pm
by tony.mon
purgeraptor wrote: ↑Thu Feb 23, 2023 2:45 pm
A cheap cosmetic mod. Buy yourself some stainless dome nuts to hold the mirrors on. You can see them when riding, and the painted ones you have with flaking paint let the view down a bit.
Re: Hi from Reading
Posted: Fri Feb 24, 2023 9:34 am
by purgeraptor
tony.mon wrote: ↑Thu Feb 23, 2023 10:21 pm
Like that idea, will do
Few other cosmetic jobs need doing, like the engine casing paint in places.
I did remove the 'Wear a helmet' and 'Use unleaded' stickers' from the tank yesterday. That'll upset The Purists
Re: Hi from Reading
Posted: Fri Feb 24, 2023 1:26 pm
by purgeraptor
Cheap eBay black clutch lever fitted.
Looks to be OK quality and fitted well.
All is good, unless it snaps off after a few applications
Re: Hi from Reading
Posted: Fri Feb 24, 2023 4:39 pm
by sirch345
purgeraptor wrote: ↑Fri Feb 24, 2023 9:34 am
After Tony's suggestion
I have been looking for mirror fixing replacement nuts, as the one's on my bike are not looking their best either. Not the easiest to find if you want to replace like with like regardless of finish or different materials such as stainless steel etc, as iirc they are domed nuts with a flange. Most don't have a flange. David Silver can still get them although a special order, but are £18.32 for four with delivery.
Or these:
https://www.ebay.co.uk/itm/M6-Flanged-D ... ect=mobile
Good luck with the new clutch lever,
Re: Hi from Reading
Posted: Fri Feb 24, 2023 10:23 pm
by purgeraptor
Cheers.
I'm going to try the stainless DIN M6 dome nuts without the flange.
Can always bung a washer underneath if needed.
£3.73 including delivery for a pack of 10 from Bolt-World on eBay.
Re: Hi from Reading
Posted: Fri Feb 24, 2023 10:39 pm
by tony.mon
You don't need a flange.
Flanges weigh more...
