sirch345 wrote:'Stormin Ben' usually recommends moving the clutch and brake levers, so they are facing more down-wards. It means you can keep your fingers, wrists and lower part of your arm in more of a straight line if you understand what I mean. I did that on mine and it certainly does help
Good call that man!
Certainly a large part of the problem can be alleviated by adjusting the levers so they are right for the way you ride
However, an equally large part comes from how you ride
I'm betting that those who have wrist pain on the storm are riding with locked elbows and straight arms
This puts unnecessary strain on the wrists as well as reducing the amount of control you have on the bike
The bars are for steering with and to hold the levers -NOT to take your weight
You should be supporting most of your body with your back with your arms bent and nice and loose
Your forearms should be pretty close to being horizontal
Not only does this mean you have less weight on your wrists, it also means that any steering inputs you make are much more efficient
Think about trying to move a heavy box across the floor.
Now imagine trying to do it by pushing at a 45degree angle to it -much harder isnt it.
Its the same when you are trying to turn the bars -if your forearms are horizontal nearly 100% of the effort goes into turning the bars
If you have locked elbows &straight arms only 50% of the effort goes into actually turning the bars, the other 50% is just you pushing down on the bars
You will find it odd & a bit uncomfortable at first as your back gets used to the extra work you are asking it to do and your triceps get used to supporting some of your body weight too. But long term you will reap the benefits and be able to be comfortable on a much larger range of bikes
I am not a lightweight by any means (over 14st on a bad day) but I have done some serious mileage on a 916 with no problems whatsoever
Here endeth the lesson
