vtr streetfighter build moriwaki madness
motostorm
Re: vtr streetfighter build moriwaki madness
Post by motostorm »
its not the dog in the fight its the fight in the dog
looks mean as crouton m8 - very nice indeed! :thumbup:
i notice on your fuelling line though, you have a very very similar dip on the rich side as i had with mine... then it levelled out as the revs rose...
it was caused by non standard diaphragm springs & drilled carb slides.
if you have drilled yours it might be well worth you plugging the holes with a bit of o ring superglued in the hole, then have another dyno run - i think you will be surprised lol!
if you have fitted the lighter springs out of a dynojet stage 2 kit, junk them and put the standard ones back in - makes a world of difference m8, maybe slot in a bmc 1404r filter as well to take advantage of the extra fuel you're squirting in!
cracking job youve done on that bud :beer:
motostorm
Post by motostorm »
cheers b+h , id have to admit none of the carb or motor mods were mine so its a bit of an unknown , all ive done with the motor is an ebc kevlar clutch kit, valve clearences , and sevicing , it was really the chassis and cosmetics i put together , but am sure more info will turn up as i believe its known to a few people on the site ,
the reason i havent interfered with it is apart from being really bad on (upto) 1/4 throttle (its piggish :shifty: ) it fuels really good , its really well set up apart from that , and its not really a bike for around town or traffic :twisted: . high seat , bad lock
the handling is fantastic :biggrin and it flies
im happy :thumbup:
It's looking great Motostorm :thumbup: Nice you got back to us now you've re-designed her 8)
I see you have USD forks now with radial calipers, a very nice touch IMHO :thumbup: Which forks did you use :?:
motostorm
Post by motostorm »
sirch345 wrote:It's looking great Motostorm :thumbup: Nice you got back to us now you've re-designed her 8)
its i believe 2005 cbr1000rr , it had a stem already fitted for a 96 blade and so dropped straight in , its very good works great , reduces steering lock tho ,
i expected the wheelbase to be short but its fine theres only about 5mm or so in it ,
the bike did require a damper tho :problem:
ive just put an r1 front on my other bike ill report back on that too , :biggrin . for me its really the storms weak point ,
motostorm wrote: its i believe 2005 cbr1000rr , it had a stem already fitted for a 96 blade and so dropped straight in , its very good works great , reduces steering lock tho ,
Cheers for the info on the USD forks. I look forward to seeing some photo's (hopefully :wink: ) of your other Storm with the R1 front end, when it's finished :D
motostorm
Post by motostorm »
no probs chris , bike is not much to look at in terms of bling , but its how i want it :biggrin
[imgImage
Uploaded with ImageShack.us][/img]
By davebikekraft at 2010-11-14
[imgImage
][/img]
motostorm wrote:no probs chris , bike is not much to look at in terms of bling , but its how i want it :biggrin
Thanks for the photo's Motostorm. The R1 forks look good IMHO, as does that single headlight :thumbup: I feel it gives the bike presence :thumbup:
