agree. might have a experiment with my spare speedo and see if there's a simpler way to get it more accurate tho. mate glued some solder under his needle to weight it and it works spot on, blob of superglue, then trim it off with nail clippers til it reads right against the satnav.Pete.L wrote:Looks like some one needs a speedo healer badly.![]()
fixed cable ones before by pulling the spring through the crimp at the end and shortening it a bit.
i reckon theyre not far out up to legal speeds but beyond that it's anyone's guess.
using gearing commander to work out the speed v rpm i should be doing 157 at 10k but the speedo shows 170, that's assuming the tacho is accurate
