how much have you dropped the forks it looks like loads
you noticed that then ....only by about 2 inch to just lower the front wheel into the fairing for a more aggressive look, have to be careful not to lower it too much as it starts hitting the top of the mudguard, i hardened the forks a little bit and this resolved that. seems to handle better in the corners now as well as on them roundabouts whilst popping my knee down, so a good little adjustment all round
Sitting On My VTR At Full Throttle Is Like Sitting On A Washing Machine At Fast Spin....No Wonder I Ride Around With A Hard On !
mines a 98 model mate......its not too complicated to wire in if you mark up wires before hand on both the wiring loom and the digi dials, the hardest bit i found was programming in the wheel dimensions in to get the right speed reading. the plate underneath was made by me.... used a bit of cardboard to mark out a shape then transfer this to a bit of alloy plate and got the grinder out, bit of black spray paint, bolt down the digi to that plate job done only took an afternoon to do the lot.
Damo81 wrote:mines a 98 model mate......its not too complicated to wire in if you mark up wires before hand on both the wiring loom and the digi dials, the hardest bit i found was programming in the wheel dimensions in to get the right speed reading. the plate underneath was made by me.... used a bit of cardboard to mark out a shape then transfer this to a bit of alloy plate and got the grinder out, bit of black spray paint, bolt down the digi to that plate job done only took an afternoon to do the lot.
Sweet mate its a Defo todo in the future then, makes it look that bit more moden and refined
You are only the second person I know of who has dropped the front end by so much. If it works for you then that's what matters
dropped the forks on mine by 1" and it was vile to ride.
