Thanks Chris. The only reason there are no decals on the fairing is because the bike has had a crash at some stage. It don't look to bad in the pics but whoever sprayed the fairing didn't do a very good job and there is a small dent in the tank.
There's going to be some big changes next year. 19ltank and CBR1000 clocks, Black frame, swingarm and fork lowers, Ohlins fork springs and a brace, bodywork resprayed Chrome (I may leave the fairing lower Black), Gold wheels, Window showing the clutch and clutch plate painted gold, wrinkled Black/Graphite paint on both the clutch and generator cover, undertail and tail tidy, led indi's all around, GSXR 1000 mirrors with indi's, Gold anodised Pro bolt bits and bobs. I may even do the Harris rearsets Gold as well. I might have a go at trying to make an all in one Mario Nava style tail fairing with a little cubbyhole, New seat cover and either modded (cut down)) seat or a different seat depending on the Nava style, Then I shall be putting Gold mesh over the rads, front scoops, fairing lower and I would like some cut outs on the forward sides of tail fairing with gold mesh.
As for performance I want to slot my cam sprockets so I can at least make miner adjustments to compensate for chain wear. Heads are coming off so I can sort the front broken exhaust stud (pipe is spot welded on at the mo
) and I shall at least give it all a de-coke, but I will probably do some light porting and lightly re-grind the valves back into the seats. I may also put some exhaust cams in as inlets.
That's my plans anyway. Whether I get it all done in a year is another thing
