harris rear-sets anyone? and lots of other bits
Moderator: VTRDark
Locked
Re: harris rearsets anyone? and lots of other bits
Cams, eh?
They are too good to pass up, so yes, please....
PM'd
grumpyfrog
Post by grumpyfrog »
I've got the fly wheel tool. just not got my fat errse round to getting the standard one machined. im down your way at the weekend and I'll take the lightened one of you; or ill never get round to doing it.
between you and geoff, my winter rebuild is getting longer. .
Don't hassle me
I'll get there at some time
ok to everyone lol.
been out all day so not had a minute to answer - and 3 have cut my fkin fone off for some reason :/
sort it all out tmoro.
mac & thumper your bits are in the post first thing :thumbup:
marravtr wrote:benny whats the inlet diam of the laser cans? :wink:
massive. the link pipes are not like ordinary linkys - they flare out to about 70mm, hence the very deep tone off these cans.
first come lol, i think steve wanted to collect them?
im easy, not arsed about a dibbing battle!
tony's got the cams tho btw for those who pm'd me. i did offer them to him before i posted this as tbf i think he would appreciate them the most, and with his recent ill fortune etc :thumbup: :thumbup:
been busy packing and sending stuff out - so far the mc's (and a freebie!), pyramid belly, carbs, 4* advancer and rearsets have been sent out :thumbup:
i may break my spare engine. may keep it. not sure yet. if i break it there will be a set of casings, 2 clutches (one ebc), another set of heads, starter etc
YETI
Post by YETI »
Wot about the bodywork ? :eh:
im sure I asked for it :(
YETI..
yeh the race bodywork is yours if you want it mate.
needs prepping proper and painting but its all solid with no chunks missing and heavy dingage :)
i was going to use this on mine but then decided i cba lol :beer:
Box arrived today Benny...
Cheers Mate. :thumbsup:
Tweety
Post by Tweety »
I'd be interested in those casings, and the EBC clutch...
ebc clutch has gone mate but i have 2 good oem ones spare.
casings???
timing casing (l/h) with good timing plugs! £20plus post
clutch casing (r/h) - incl water pump these are rare as rockinghorse poo and im not giving it away as this one is unmarked as in not been down the road! £50 plus post
other bits -
fairing bracket - someone asked for this?
top & bottom yokes (straight)
pair of manual cct's
exhaust headers - black
good starter motor,
cam covers,
front and rear cylinder heads,
2x ecu, 2x cdi
oem coils
sprocket cover (2) with clutch slave
straight rear subframe,
2x air boxes - one with vacuum relief valves fitted!
k&n filter
also got a spare swing arm if anyone fancies doing the brace mod, but the l/h chain adjuster is stuck solid lol... it'll come out but will take some welly -
i have new chain adjusters to go in after the old ones are out.
rear sprocket carrier with new 41t sprocket and new 15t front sprocket.
both sides rads - and fans
2x oem oil coolers - was considering joining them together with tees :think:
standard clip-ons (bars)
also all the fixings, spindles, linkages, lock set
electrical stuff, good wiring loom
starter relay/solenoid (to go with starter)
sidestand and switch!
rear hangers
the front n rear wheels are still here if anyone wants them.- these have good straight discs with very little wear
front n rear brake calipers with good seals - iirc they have ebc hh pads with loads on
complete 2001 dash with lowish miles (cant plug it in to check but is ~20k)
and a separate low miles speedo, on it's own.
speedo sensor (2)
oem front mudguard in white
light flywheel - iirc someone said they wanted this????
race / trackday bodywork - yeti has first dibs in on this!
stuff thats gone / provisionally gone
finned r/r
lightened flywheel - grumpyfrog?
pyramid belly
+4* advancer
billet cams - tony.mon! (sorry guys - i did give tony the option on the cams before i decided to part the rest out!)
laser cans
oem fairing, tail, seat cowl etc
seat
lh switchgear
forks
rear shock
19L tank
carbs
headlight
one pair of cyl heads - still got one set)
2x sets of oem cams
timing cover (still got 2 spare)
clutch cover (still got one spare)
ebc clutch, complete
cbx master cylinders & levers - (still got the oem ones iirc)
harris rear sets and heel plates
oem footpegs
1x pair of long stacks - (still have short ones)
ebc air filter
1x pair of manual ccts (still have 1 set)
thumperslaw
Post by thumperslaw »
Got in the post the other day :thumbup: thank you!
Would the last dash plug in and play?
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
thumperslaw wrote:Got in the post the other day :thumbup: thank you!
the what mate???? you mean the speedo? you'd need to take your dash apart to fit it. it goes inside the clock housing, it's only 3 10mm bolts and a few xheads on the back, and one connector to unplug.
takes 20 mins tops to swap over. (ideal for mot time lol)
the complete dash is from a 2001 model - pre facelift, ie it is not the half digi dash, but it will fit all models 97- 2001
Grumpyfrog http://www.vtr1000.org/phpBB3/posting.p ... 3#pr278409
Are these standard callipers you have listed or CBR or something? I know you mentioned CBR earlier so I'm presuming they these ones are standard but thought I would check. If the sale fall through on the CBR ones I would be interested mate.
they are standard calipers mate - i just changed the master cylinders and used ebc pads and theyre more than adequate for the road & track. all have new seal approx 5k ago.
twintin
Post by twintin »
How much for the sidestand and switch?
Mark
its not rust it's character
twintin wrote:How much for the sidestand and switch?
Mark
you will have to use angel mail now for this to reach benny , but he will reply with collection only or he will leave it at the gates if you cant get in . .
Locked
