Rear indicators
Re: Rear indicators
scouse645 wrote: Thanks mac for your help, so basically if i put the new relay on i can put some led indicators on? on your picture it looks like there is only 2 pins, is that right?
Yes that is right, the std Honda one is 3 pins, the new LED relay only has 2 coz that's all it uses. What you have to look out for is the different Honda item that is a 4 pin plug as it won't fit. On that one its a square plug, the one you need is flat with the pins in a row.
J&S Accessories do them but don't always have the 3 pin in stock. An easy way to do it is to take the std one off your bike & take it with you if you are getting one from a shop, then you can just ask for a LED relay to fit.
If buying on line just read the ad fully to make sure it's correct.
scouse645
Re: Rear indicators
Post by scouse645 »
Whilst i'm waiting for the led indicators i have ordered i have received the led relay, is it ok if i put that on for now with the old indicators? there may be more questions when i get the indicators as i'm not sure about the colours of the wires, the new one's look different. :?
Re: Rear indicators
scouse645 wrote:Whilst i'm waiting for the led indicators i have ordered i have received the led relay, is it ok if i put that on for now with the old indicators? there may be more questions when i get the indicators as i'm not sure about the colours of the wires, the new one's look different. :?
No dont put it on yet It wont work with the bulbs.
Re the wires, on the rear there are 3 connections on the loom, one is a double plug & then you have two more single plugs. Start off by putting two same coloured wires from the new indi's in the double plug then connect the other two to the single sockets.
Now try the Indi's.
One of two things will happen...
1/ They will work fine.
2/ They wont work as you have connected wrong colours to wrong plugs, easy fix just swap them over.
3/ The indi's will flash but on wrong side to switch direction...ie right flashes when you switch on left ...easy fix just swap over the two single wires.
4/ They work fine...box all all back up & go for a ride with a smug grin of a job done correctly... :thumbup:
5/ They wont work at all ...swear a lot & find something not connected to your bike to smash the shite out of with added swearing.
6/Ignore number 5 as they will be fine. Ignore number 2 as I don't think it will make a difference. Ignor number 7 as there isn't one.
scouse645
Re: Rear indicators
Post by scouse645 »
Cheers for that, even i should be able to follow your guide 8) should get the indi's by friday, hopefully i will be end up with number 4 on your list :lol: will report back.
scouse645
Re: Rear indicators
Post by scouse645 »
Indi's came today, all fitted and working fine, i would be a liar if i said they worked first time :lol: a couple of goes and they were done, i refer to item 4 in mac's list above as my next action, complete job was 21 notes, not too bad, thanks mac for your help and anyone else who contributed :thumbup: it was a good day all round as i rang mce insurance for a quote and got 15 months for 107 notes :beer:
Re: Rear indicators
Yeeeeah ! Well done that man... :thumbup:
So what did you get wrong first time then...?
scouse645
Re: Rear indicators
Post by scouse645 »
I think it was just that the end of the wire that goes in the bullet connector was a bit smaller than the old ones, i just pinched them up a bit to make then tighter and that was it, 18 led's are a fair bit brighter.
Re: Rear indicators
Well done, success :clap:
