Front Discs
rollingthunderx2
Re: Front Discs
Post by rollingthunderx2 »
Get a felt tip pen and hold it just off the disc,spin the wheel.. move it in, it will touch where it is warped. Hit here with a rubber hammer.
Or
Put a nut and bolt with washers through the bobbin holes,tighten it up..not too much, just to grip the bobbin.. spray some brake cleaner into it then turn the bolt back and forth to get the sh1t out of the space between the disk and bobbin, the bobbin needs to be turned.
Some other bikes disks fit,and are cheaper... CBR400RR
scouse645
Re: Front Discs
Post by scouse645 »
rollingthunderx2 wrote:Get a felt tip pen and hold it just off the disc,spin the wheel.. move it in, it will touch where it is warped. Hit here with a rubber hammer.
Or
Thanks, i have done all those things but still the same, just going to have to buy new as wasted too much cash already :x
mattycoops43
Re: Front Discs
Post by mattycoops43 »
scouse645 wrote:
gabi81 wrote:I'm in the same boat my discs are warped
I personally when it comes to brakes buy new don't play with 2nd hand
Armstrong are not bad as long as u don't do track days or the extreme choice china
Thanks, i took mine to a place in grantham today to get them sorted, he showed me them after and they were fine, i went home and put the wheel back on the bike and went for another mot, guess what? failed again, he showed me on the rollers how bad they were, no better than the first time :x i'm not wasting anymore money, as you say buy new, that's what i will do.
This happened to me, I sent mine to motoliner and they still failed, sent them back for another go and they failed again. cba anymore, new it is but what a price.
scouse645
Re: Front Discs
Post by scouse645 »
The bloke i took them to said they were fine, obviously it doesn't always work. :( Yes 300 squids for genuine ones, bit stiff for what they are, unless anyone knows anywhere cheaper?
Re: Front Discs
You might as well pay the extra and get decent ones:
http://www.bikehps.com/braking/
Another £100 gets you pads as well.
scouse645
Re: Front Discs
Post by scouse645 »
tony.mon wrote:You might as well pay the extra and get decent ones:
That price would take some justification, i don't use it enough for that, i'm moaning about spending for originals, i told my misses when i got this bike i wouldn't be spending much on it, she reckons that was a bit of a porky :shh:
Re: Front Discs
Well, I run Braking Wave discs on mine, and it stops quick enough to keep me from running into stuff, so gets a :thumbup: from me.
Once I get the Blade front end on I'll need to buy some 330mm discs, and then my existing front end will be up for sale, WP springs, and all.
I will see if I can persuade the F41 calipers to fit the Blade forks, though- I like those, and I have a radial MC to match up to them at some point.
Re: Front Discs
tony.mon wrote:Well, I run Braking Wave discs on mine, and it stops quick enough to keep me from running into stuff, so gets a :thumbup: from me.
Tony the calipers will drop on no problems as they are the same as the blade components
gabi81
Re: Front Discs
Post by gabi81 »
i told my missus same but ive spent 300 so far just on bits and bobs and im about half way done :wtf:
if money is an issue try these on http://www.ebay.co.uk/itm/171115890360? ... 1438.l2649
ive been told they should fit but im sure smbdy would jump and correct me if im wrong :Beer Popcorn:
Aha you know what it is black and yellow...black and yellow !!!
mattycoops43
Re: Front Discs
They will be the right fitting, but you can get waveys from the uk that price.
I know people who are running round with waveys and they are fine, and I know people who have bought them and they have warped really quickly. I have also been told by mot man they have tested bikes that have cheap copy discs that look like originals and they have warped on the way to the mot test from new. Not really prepared to risk £150 as if they warp, your Honda discs have then cost you £450!!!
scouse645
Re: Front Discs
Post by scouse645 »
At least i got a debate going :) i took lloydies advice and bought some from david silvers, they are originals, had to raid the secret fund :lol:
Re: Front Discs
mattycoops43 wrote:They will be the right fitting, but you can get waveys from the uk that price.
Agree entirely.
There are some oriental ones that have the slots cut too close to the outer edge of the disc and they crack- I had a rear fitted and there were two or three cracks in it after a few months. The Braking Wave ones I have leave enough "meat" on the disc, and don't have this problem- I wouldn't suggest them otherwise.
I posted a report on the cheap knock-off discs a while back.
Glad you're sorted, mate.
mattycoops43
Re: Front Discs
So are there any other waveys that have a definite good rep? I know there are good ones out there, but didnt want to risk duffers.
Braking wave, what others have people used themselves that have lasted.
adyf
Re: Front Discs
Post by adyf »
Armstrong discs,goldfren pads,mines USD blade front but great discs.
mattycoops43
Re: Front Discs
adyf wrote:Armstrong discs,goldfren pads,mines USD blade front but great discs.
I'm really sorry but I can't take that recommendation as goldfren are without doubt the shittest pads in the universe. I tried them on the fazer and my mate thought the brakes were warped when he rode it JUST because of the pads, changed to originls and they were about 400 times better.
