As Lloyd said there's not much chance on them moving but threadlock wont go amiss Just be aware that's the reason for them notches.
Ignition or Yoke Replacement
Re: Ignition or Yoke Replacement
Jamoi wrote:Thats good news Lloydie, thanks![]()
I could always pop a bit of thread lock on the pinch bolt too. Would lower clip-ons work with the tank/fairing etc?
Sent from my GT-19505 using Telekinesis
Why do you want lower clips-on's ?
Isn't your butt up in the air enough already...off the bike that is...
I think I may have just answered my own question...
Forget the lower bars try a rubber ring for your ring...
Haha cheers Mac, can you recommend a place to buy a ring for your ring? ...pimpyourring.com?
Just fancy a more aggressive position, might help shift a bit of weight forwards too, you reckon?
With my high bar conversion, I was getting tonnes of opposite lock on the bars out of corners
Jamie
There you go...Jamoi wrote:Haha cheers Mac, can you recommend a place to buy a ring for your ring? ...pimpyourring.com?
http://www.ebay.co.uk/itm/INFLATABLE-CO ... 20ca74b4a1
Bwahaha!
"Can be easily wiped clean" - incase you enter a corner with a little too much enthusiasm!
"410mm diameter" - even fatties can benefit from our elbow dohnut!
Jamie
