Advise on Exhaust - sorry if it has been asked before
Re: Advise on Exhaust - sorry if it has been asked before
All good advice. Nice to see you found Lloydies twin. Yeh stay away from the K&N not worth the expense and dyno time required to get things tuned in as best as one can with a standard engine. You'll most likely find yourself chasing you tail moving a dip in the curve around.
Get some new cans and start with Hawks carb thread. It's a good chance to get to know the bike, see how she runs and tinker with things. See which way you want to go next. If you want a good washable filter with a little more airflow then the BMC Street filter is the one to go for, but you would most likely need a jet kit then so you can go the other way on the needles if needs be.
- carmanbikes
I have a new K&N filter I was gonna sell but after this going have to through it in bin
Carman, I have a K&N in mine with Scorpion cans and a Factory Pro Ti jet kit. I followed the instructions in the jet kit and have found it ok fella. Try it and see how it works for you.
I have one sitting in it's original packaging waiting to stick on eBay once all the firms have got rid of old stock and the prices increase. They went up this year from about £60 to £100. increase in cotton prices or something.have a new K&N filter I was gonna sell but after this going have to through it in bin
http://www.knfilters.co.uk/search/produ ... od=HA-0011
I've fitted K&N filter and dynojet kit to two firestorms in the past and they both ran perfect, they went on the dyno for a check and no changes needed, good power, no big dips. both d/j kits fitted as per instructions with slides drilled and middle size supplied jets fitted. one bike had Arrow carbon cans, the other remus high level
That's interesting Popkat. Bit of a marmite mod, the K&N filter.
Mine also runs a K+N, and has no holes anywhere in the range.
Maybe you just have to know how to set it up.
lloydie wrote:sorry you should of said and i would of put a note on my calender !!chric wrote:thanks for that wanted them as a sparelloydie wrote:http://www.ebay.co.uk/itm/HONDA-VTR-100 ... 2333bc4cc0
check these out i knew id seen some for sale
i was thinking about bidding too but then i remember i dont like burning my boots .
Be worth the wait
- carmanbikes
I will stick it in and try it, The K&N that is
I did run one for a while and couldn't tune the dip out .
I will try again with the new engine
