Struggling to sync carbs
Seeker 77
Re: Struggling to sync carbs
Post by Seeker 77 »
I never worked on my last Firestorm, just a few cosmetic bits and pieces. I never knew what a bitch is was going to be to work on, getting access to anything is almost impossible! My Superduke was about a thousand times easier to do the same jobs on
Seeker 77
Post by Seeker 77 »
lloydie wrote:Did you block up the little pipes from the carbs to the pairs ?
Yup followed this guide:
http://www.superhawkforum.com/forums/mo ... how-20918/
Good as If you left them open it'll run like crap
mellis wrote:I never worked on my last Firestorm, just a few cosmetic bits and pieces. I never knew what a bitch is was going to be to work on, getting access to anything is almost impossible! My Superduke was about a thousand times easier to do the same jobs on
You're just finding your way around the bike Mark, once you've accustomed yourself to it, you'll find they are not that hard to work on :)
Seeker 77
Post by Seeker 77 »
I do hope my hands shrink then Chris! Slightly alarmed to find a rusty thread cutting tool in between the V of the cylinders whilst working yesterday 8O
Last thought, front or rear vac takeoff left open after balancing?
Leaving the vac pipe unplugged will give the sort of symptoms you describe.
Seeker 77
Post by Seeker 77 »
tony.mon wrote:Last thought, front or rear vac takeoff left open after balancing?
I bunged the rear T-piece pipe and replaced the front bolt, if that's what you mean? I removed the PAIR altogether and bunged the airbox and pipe as per the link above. I haven't ridden it since but on firing it up it was still bogging down and then picking up again.
darkember
Post by darkember »
The front hose from the airbox to the rocker cover can be a pig to seat properly give it a check
mellis wrote:I do hope my hands shrink then Chris! Slightly alarmed to find a rusty thread cutting tool in between the V of the cylinders whilst working yesterday 8O
My hands are hardly small, I take XXL gloves :)
Seeker 77
Post by Seeker 77 »
I think you might have the answer to all my dramas Lloydie, I'm wondering whether the dramas I had in the other thread were caused by not doing this properly. I'll leave it well alone from here on!
Well there's a first lol
Did you mess up removing the pairs ?
Seeker 77
Post by Seeker 77 »
Not sure mate, but I buggered something up! All seems to be running as it was before, although the farts are just as bad they were. I'm really not sure that there's much I can do to it without messing about with the jetting. It deffo runs a lot worse on the open cans.
Seeker 77
Post by Seeker 77 »
Well after all that it turns out that the carbs were absolutely fine, but the bike was running very lean indeed and that was causing detonation (actual) before the inlet valves were fully closed. Thanks to Kev L I managed to adjust the pilot screws and all is running perfectly again. It was the addition of some very free flowing cans that caused all the misery!
Good news mate :thumbup:
That all adds up and explains why it was worse after your mods and also the flames we could see in the video.
Result :thumbup:
