badly needed
Moderator: VTRDark
Re: badly needed
AMCQ46 wrote:dropped off the package this morning........ its down to myHermes now.
I will track it tonight and see where it is.
did he get the welding done already?
briiliant, hes bringing the bike this wednesday to a guy who says he will have a look and try and get the broken lugs welded back in place.thankfully the lugs that gave way he still has them.
Re: badly needed
Big thankyou to Al. the parts for stevies bike just arrived.. :thumbup: :thumbup: :thumbup: :thumbup:
Re: badly needed
remember to put the clutch pushrod in the correct way round. you should be able to see the marks were the seal rubs on the shaft....... this is the sprocket end, the hardened and ground end is the clutch end.
Re: badly needed
AMCQ46 wrote:remember to put the clutch pushrod in the correct way round. you should be able to see the marks were the seal rubs on the shaft....... this is the sprocket end, the hardened and ground end is the clutch end.
didnt realise there was a diff in the two ends, happy days :thumbup:
