Newbie here
Re: Newbie here
Right then guys where do I need to be heading to get advice on CCT, and RR, mine has been stored for many years and has the original RR and CCT fitted. Its only covered just under 7k from new.
Re: Newbie here
rayboy68 wrote:Right then guys where do I need to be heading to get advice on CCT, and RR, mine has been stored for many years and has the original RR and CCT fitted. Its only covered just under 7k from new.
CCT...http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=28583
CCT...http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=22720
R/R...http://www.vtr1000.org/phpBB3/viewtopic.php?f=31&t=5308
Basicaly spend some time reading through this section...http://www.vtr1000.org/phpBB3/viewforum.php?f=31
For CCT's go with Bassa manual conversions...
R/R your best bet is to source a Mosfet type one. Not plug & play but it can be fitted without the need to cut any wires, you can unpick the block & use the cripms already fitted.
After you've sorted those two items out your next must do is to check & lube the swingarm linkages.
Then move on to fettling things like brakes & forks.
Then move on to the long long list of unnecessary mod's...
Re: Newbie here
cheers SteveSteve97 wrote:and im in Evesham![]()
so if you need help........
