Project resurrection
Re: Scored a wreck
Not insisting Mac, it was a 15 second search
Re: Scored a wreck
I can confirm that it has a rough texture, but not like sand paper. It's grippy but I doubt lint would stick to it. U can buy it in a 2 part paint which u mix the base product with a hardener and use a spray gun to apply. I opted for the can as I don't have access to a compressor. The rattle can stuff isn't as durable as The 2 part product.Varastorm wrote:Nope, none there either, unless it goes by another title.
It was only a quick ebay search though.No results were found for your search "truck bed coating"
Anyone know if it's like a sandpaper texture? Touch it with a polishing duster & your there for hours trying to get the lint off?
Re: Scored a wreck
Nice work Antman
Re: Scored a wreck
Good job that
On the underside of the swingarm and such you can use tetra seal underbody coating
it does a great job of protecting stuff from stones etc
I believe that the Aprilia curved rad fits the bike
Re: Scored a wreck
Well done ant, how did you find the truck bed liner spray?
What's the radiator you're using on the front there?
If it's broken; should it move? Yes: Use WD40 No: Use cable ties. Now it's fixed!
Re: Project resurrection
Loving that two brothers system!!
Re: Scored a wreck
Hey mate, the radiator is an eBay one for a Suzuki tl1000Ant wrote:Well done ant, how did you find the truck bed liner spray?
https://www.ebay.com.au/itm/272436617572
I used the original oil cooler mounting bracket on the top and tig welded a bit of ally flat bar on the bottom which bolts where the Pairs connected to the cam cover
am I the only 1 having trouble viewing all ant's pics?
trying very hard to get over the 50 posts hurdle
- alanfjones1411
Noeezee29 wrote:am I the only 1 having trouble viewing all ant's pics?
