Bike not starting
Re: Bike not starting
Traced the pic...terminal burnt out... this is what happens when the RR fails...
That block conector coulkd be reused or replace it... It's fiddly but you can unpick the conecters from the block. You will need to either unpick or cut the burnt one off to trace it back to see how far up the burnt bit is...You need nice clean copper for best conection.
If your sensible you will replace it with a Mosfet RR, that will require removal of that block conector...
If your not so sensible just get another finned shunt type RR like the one that has just failed, that will be plug & play & you can get new block connectors on e bay.
